![]() check the fuse box but did not see any for head lamp except the maxi fuse located at engine compartment.
Bulbs are fine, and wires. The driver's side Headlight won't turn on.! if it is Light switch, how do I fix it? thanks a lot! Last edited by chingalong; 07-11-2009 at 01:25 PM.. |
Switch
how do you clean and remove carbon from switch?
is it easy if I take it out from steering wheel? do I have to use a 1000 grit, or what type of cleaning material? thanks a lot. |
![]() Join Date: Feb 2008
its easy to take it off the column. cleaning it is the tricky part. theres a white plastic cover that you need to remove to get to the little copper finger things. 1000 grit should remove whatever buildup is there. when you're done, glue the cover back on and reinstall.
