looks good guys. I would prefer the s-afc plan and then run it on the dyno. I think either way you are going to want to run it with a wideband a/f meter (not a gauge) and most dyno shops have one. I would not trust a a.f gauge to do a baseline tune, I would use it to give you a warning that something is not working correctly. It's kinda like a EGT gauge, you don't tune with it, you just use it to tell you that everything is working properly. BTW, you can tune with either one. I dont think you need a FMU with the s-afc, but you can do what you want. I don't have one. However, if you run a 255high pressure pump your fuel pressure will rise since the stock regulator can't handle the flow. You don't need the 255 pump, the 190l/hr will be more then enough fuel to make enough power to blow the stock pistons and rods :-). I would just get the 190l/hr pump and use the stock regulator. Try to keep at least 4" or so between the mafs and the compressor so you don't get any turbulance in the mafs.
Adam
'89 coupe KA24DE+T
14.1 @ 104 MPH
'88 Celica All-Trac turbo
stock, but no more ecu codes!!
