Old 08-04-2003, 05:39 PM   #1
DuffMan
DuffMan's Avatar
Originally posted by old_s13
2) Power steering. The SOHC components from what I hear are useless, so dont use the PS from your SOHC.. just remove them all and deal with it later.
- Mike
WRONG!
Anyways, power steering isnt much of a hassle with sohc or dohc parts, but if you REALLY want to eliminate it, the procedure is to remove the belt, and you have to disconnect the two hardlines on either side of the rack and turn the wheel from side to side to get the fluid out, which is pretty messy.
Its almost as much work to eliminate it, as it is to set it up with the SR.
