Old 08-06-2003, 12:22 AM   #1
the3SecondJerk
the3SecondJerk is an unknown quantity at this point
Sr runs crappy under load...revs perfect in neutral LOL
Exactly what it says... My Sr in the garage runs great idles nice revs fast and smooth. When I leave the garage and go to the road its a different story. Under load, it spits kicks and sputters. Thought possible vaccuum leak but cant really find anything. Maybe a fuel problem? Have 255lph pump. Hks ssqv. stock IC. Also using all emission control items such as carbon canister, AIV, etc. Please help me! Need car soon!
Thanks to everyone that can help, in advance!
Dan
Drive it like you stole it.
the3SecondJerk is offline   Reply With Quote
Old 08-06-2003, 12:49 AM   #2
sil80phobia
sil80phobia is an unknown quantity at this point
sounds a lot like a boost leak.. see this thread:
http://www.zilvia.net/f/showthread.p...threadid=33652
Dave
sil80phobia is offline   Reply With Quote
Old 08-06-2003, 07:12 AM   #3
MovinUp-1
MovinUp-1 is an unknown quantity at this point
or an electrical problem. Check your grounds and make sure your positive connection is good.
Allen
Delta Region SCCA
SM 1990 240SX SR20DET
MovinUp-1 is offline   Reply With Quote
Old 08-06-2003, 10:49 AM   #4
sil80phobia
a few other items to check
- plugs
- do you have a fuel pressure gauge hooked up?
when you punch it, does it even hit/maintain boost?
Dave
Old 08-06-2003, 09:29 PM   #5
the3SecondJerk
OK so the problem was a ground. But when I punch it the turbo screams like it is boosting but the power just isn't there. The hks ssqv let's out pressure fine when I let off, but again it feels like the engine is choking or something the power just doesn't egual the sound the engine, turbo , bov make though. Any ideas? I am checking all piping in the morning I think maybe some hoses aren't tight enough.
Old 08-06-2003, 11:58 PM   #6
s0ldats
s0ldats is on the path to ruins0ldats is on the path to ruin
leakage, dawg. (actually i don't know... but it sounds like it)
s0ldats is offline   Reply With Quote
Old 08-07-2003, 01:03 AM   #7
DudeYourSoOOJDM
DudeYourSoOOJDM's Avatar
DudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud of
Send a message via AIM to DudeYourSoOOJDM
What does your boost gauge tell you?
If you dont have one...now would be a good time to invest.
There are many things it COULD be.....could be bad plugs,coilpacks, ignitor chip, MAFS wigging out, bad ground, fuel pump dying, bad FPR.......its gonna be a process of elimination.
try to distinguish whether you problem is fuel or spark related.....that helps narrowing it down.
Who knows, it could be as simple as a hose clamp loose....or maybe a hose w/ a crack tht is not noticeable but only cracks open under load.
DudeYourSoOOJDM is offline   Reply With Quote
