Old 08-07-2003, 10:56 PM   #1
chokudoriS13
chokudoriS13 is making a name for him/her selfchokudoriS13 is making a name for him/her self
Send a message via AIM to chokudoriS13
Could a 1.3 bar radiator cap make my water pump gasket blow?
If so, then I am an idiot. I picked up a Cusco High Pressure radiator cap today (it came off an S13 front clip). After about 10 min. of driving, I overheated... Filled up with coolant, and made it about 10 miles before it leaked out again. This time I realized its leaking from the water pump area. I'm thinking its the housing gasket. Do you guys think the higher pressure (1.3 instead of the stock .8/.9) caused the gasket to go?
S13/86/Miatas/DR30/MX83/E36 M3/S60R/E30 M3 -gone!
Now: Porsche 993/MK7 GTI
chokudoriS13 is offline   Reply With Quote
Old 08-07-2003, 11:03 PM   #2
chokudoriS13
The suspect:
Old 08-08-2003, 06:10 AM   #3
chokudoriS13
Update: took off the water pump... NO GASKET! Just minimal amounts of gasket sealer... I guess the previous owner had a cheap or shady mechanic. Obviously it didn't hold with the extra pressure...
Old 08-08-2003, 07:54 AM   #4
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
there is no OEM gasket for that...just RTV.
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
Old 08-08-2003, 10:03 AM   #5
boosteds14
boosteds14's Avatar
boosteds14 will become famous soon enoughboosteds14 will become famous soon enoughboosteds14 will become famous soon enoughboosteds14 will become famous soon enoughboosteds14 will become famous soon enough
Send a message via AIM to boosteds14
I would not use it. greddy sells the 1.1Bar radiator cap and when i put that on my car, my water temp was all over the place, then i started to get coolant leaks EVERYWHERE.
240SXONE
www.240SXMOTORING.com --- One Stop Shop for Your Nissan 240sx
boosteds14 is offline   Reply With Quote
Old 08-08-2003, 10:46 AM   #6
DRFT
DRFT is making a name for him/her selfDRFT is making a name for him/her selfDRFT is making a name for him/her self
So your saying a greddy radiator cap can cause all that boosteds14?
ApexNetwork.Net
Sacramento & Norcal Forum
DRFT is offline   Reply With Quote
Old 08-08-2003, 12:00 PM   #7
chokudoriS13
Yeah, but you may have had the same issue (old gasket sealer letting the pressure escape). I wish more people with high pressure cap experience would reply. I don't want to put it back together only to have it pop on me again, and I don't have the stock cap (left it on the clip I got the Cusco from).
Old 08-08-2003, 12:02 PM   #8
nightwalker
nightwalker's Avatar
nightwalker is an unknown quantity at this point
thats odd, when I put my Greddy high pressure cap on, my car actually ran a little cooler (that and it was coupled with redline water wetter) The temp. use to creep a little past the middle area, now it just stays right below it and doesn't even budge. Looks like you cooling systems need some tuning up.
In life, we often cast the line of hope fishing for the best possible opportunity. Sometimes with enough effort, the things we catch are nothing short of amazing.
nightwalker is offline   Reply With Quote
Old 08-08-2003, 12:05 PM   #9
boosteds14
boosteds14's Avatar
Well I am not saying it will cause that but it happened to me.
When i put the stock one back on, the Temp was back to normal and all my leaks went away.(or course after loosening the leaks, sealing again, then retightening)
It also happened to one of my local customers which was also a KA-T. Yet on Hondas they work like a charm.
I dont know what to say.
240SXONE
Old 08-08-2003, 12:08 PM   #10
boosteds14
boosteds14's Avatar
Ya it did lower the temp on this kids 93 240. And he had no problems with it and no leaks. I guess I had a bad experience with it.
OH Well, if it is working for you that is Great!!!
240SXONE
Old 08-08-2003, 12:29 PM   #11
chokudoriS13
weird... 1.3 is the lowest pressure cap for Cusco
PRESSURE MAX COOLANT TEMP
1.3 bar 105.0 deg cent
1.9 bar 110.3 deg cent
2.0 bar 112.6 deg cent
2.3 bar 126.5 deg cent
Old 08-08-2003, 06:34 PM   #12
Got Sileighty?
Got Sileighty? is an unknown quantity at this point
dude just get an SR, and stop showing off that u have a CUSCO radiator cap hehehe jk.
on a serious note, change your oil already.
Got Sileighty? is offline   Reply With Quote
