Old 07-07-2007, 09:16 AM   #1
flytwa78
flytwa78's Avatar
flytwa78 will become famous soon enoughflytwa78 will become famous soon enoughflytwa78 will become famous soon enoughflytwa78 will become famous soon enough
hydrolic E-Brake
I was wondering what is the general opinion on converting to hydrolic E-brakes for the S-14
I am going to do brake upgrade with brembo calipers (from an R33 GTR, got it for free) with Project Mu dics. Then a friend suggested switching the E-brakes to Hydrolic ones using the calipers to lock up. I was considering this since it may be easier to do (instead of dealing with the drum e-brake, which I still need to purchase).
What do you guys think, use the drum ones or the hydrolic ones?
flytwa78 is offline   Reply With Quote
Old 07-07-2007, 09:22 AM   #2
mr_240sx
mr_240sx's Avatar
in your scenerio seems like hydrualic e-brake would make sense....thats what im doing with my drift car as well because i got s15 rear calipers and the ebrake cables dont work with the s13 chassis.
mr_240sx is offline   Reply With Quote
Old 07-07-2007, 09:24 AM   #3
Dousan_PG
Dousan_PG's Avatar
drum
hydro is only ON OFF
with drum u have more control
i would never do hydro
ive driven a few cars with it. ugh. it sucks, imo
less effort, but if u cant do that with stock (and yes stock is easy to make work FANTASTIC)
then you shouldnt be drifting.
Aaron
Pink GodziRa
Old 07-07-2007, 09:40 AM   #4
420sx
420sx's Avatar
420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future
just upgrade your stock rear with nice pads lines and get a staging brake for the cabin.
same thing as hydro, its inline slave, so you still use brakes as normal but u can use just rear by pulling the handle.
really no need to upgrade rear to bigger, most braking is in the front. imho.
hydropgrahics!
ls1......
420sx is offline   Reply With Quote
Old 07-07-2007, 09:42 AM   #5
rps13drift
rps13drift's Avatar
rps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfection
I just installed a hydro e-brake in my track car! A real lot of work is involved to get it in/working right but i think its rad!
rps13drift is offline   Reply With Quote
Old 07-07-2007, 01:30 PM   #6
McRussellPants
Im putting one in right now.
its not easier by any means.
and wether or not it works better is a matter of opinion.
I bought the kit from Driftworks in the UK, its got a smaller master than the bonerjam CNC kits, so we'll see if it haves the controllability that dousans talking about.
McRussellPants is offline   Reply With Quote
Old 07-07-2007, 04:30 PM   #7
driftenthusiast
driftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to alldriftenthusiast is a name known to all
Its not hard to install if you use stainless steel flexible lines instead of hard line. the is a place in the front to hook in to and a place in the rear pretty straight forward.
driftenthusiast is offline   Reply With Quote
Old 07-07-2007, 04:39 PM   #8
nissan_driver24
nissan_driver24's Avatar
nissan_driver24 will become famous soon enoughnissan_driver24 will become famous soon enoughnissan_driver24 will become famous soon enoughnissan_driver24 will become famous soon enoughnissan_driver24 will become famous soon enough
Send a message via AIM to nissan_driver24
what's wrong with drum brakes in the back??? i just installed them on my car and they work perfect. I was considering using a hydro e-brake but why do that when there's something offered stock from nissan. plus using a drum brake for like drifting would be nice cause u don't heat up the caliper to lock up the wheel during lets say drifting... can't beat two with one...
i'm not sure if i make any sence to any1 i'm kinda exhausted from work...
--240sx Driver Since 2002 to 2013--
nissan_driver24 is offline   Reply With Quote
Old 07-07-2007, 04:40 PM   #9
LB.Motoring
LB.Motoring's Avatar
Originally Posted by Dousan_PG View Post
drum
its true,
you can scrub off some speed with out Fully locking up the rear, it gives you a little more control, rather than an On Off situation,
you should just stick with the stock ebrake drum setup, and call it a day.
Robby Leuer
Old 10-26-2007, 06:33 PM   #10
PoorMans180SX
PoorMans180SX's Avatar
Personally I think more control could be had if everyone didn't use those lightning-pole-long e-brake handles, and a smaller slave, like some kits come with.
Who likes to work on drum brakes?
Sorry for the bump of a old thead, but I'd like to start more discussion on this.
Old 10-26-2007, 08:34 PM   #11
rps13drift
rps13drift's Avatar
You mean something like this? Im using a cncbrakes.com hydro staging brake for my ebrake. I believe there is a write up on this particular one on here some where so all your question can be answered! if not pm me and ill answer them!
Old 10-26-2007, 10:42 PM   #12
Slip&Sliden 240
Slip&Sliden 240's Avatar
Slip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfection
Here is my CNC brakes, brake.
Slip&Sliden 240 is offline   Reply With Quote
Old 10-27-2007, 06:47 AM   #13
s13coupedrfter
s13coupedrfter's Avatar
s13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond repute
I've had my hydro e-brake for the last 5 events and I love it! The whole project cost around 300 bucks. One thing about the unit is before you install keep in mind that after you bleed it the throw is shortened alot.
You can see how I spliced into the rear brake line with braided line for ease of install.
s13coupedrfter is offline   Reply With Quote
Old 10-27-2007, 11:13 AM   #14
PoorMans180SX
Nice pic. Thanks.
Anyone use shorter handles? for less leverage and the ability to adjust brake lock more?
Old 10-27-2007, 09:03 PM   #15
s13coupedrfter
Instead of guessing about leverage before you even install it, try it first then adjust as needed.
Old 10-27-2007, 10:48 PM   #16
projectRDM
projectRDM's Avatar
I don't see the need for any of this, an ebrake is just a parking brake. Park the car, engage the brake. Hell I used to carry around a brick in the trunk, works fine, and really damn cheap too.
FORMERLY R240NA
Old 08-29-2009, 06:13 PM   #17
dkwasherexd
dkwasherexd's Avatar
dkwasherexd is an unknown quantity at this point
Send a message via AIM to dkwasherexd
has anybody tried this on a fc? I need to do something about my ebrake, its completely dead... i replaced new pads,a nd tightened all the cables, now its dead..
dkwasherexd is offline   Reply With Quote
Old 08-29-2009, 06:50 PM   #18
GSXRJJordan
GSXRJJordan's Avatar
It's HYDRAULIC for Christ's sake.
drum
Drive my car next time we're at an event together. I run the CNC Brakes 3/4" inline brake with their handle braking Z32 rears with semi-metallic street pads, and I have tons of control. Can just give it a squeeze to balance the car in a corner, or slam it to instantly lock my 285/30/18 Pirelli PZeros.
It was one of the simpler things I've done, but maybe that's just me.
Exactly the unit I use. It's perfect. $90 + $100 or so for the lines. My write up is in the Fabrication Thread, but here's some pics:
Drifting man. Drifting. Trust me Russ, it's popular lol.
Exactly the same process as a 240.
I can install this in anyone's car locally for less than $300, with the plate so your trans tunnel won't flex. I even got my interior pieces to fit around it with just a tiny bit of cutting. Being able to modulate the rear wheels easier than turning down the volume on the radio is the shit.
Old 08-29-2009, 06:58 PM   #19
lazysk8er2
lazysk8er2's Avatar
lazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud of
lol at the responses 2 years later hahaha...awesome
Well i have a 95 240 and i like my cars low... But my parents don't like my wheels tilted
________________________________
lazysk8er2 is offline   Reply With Quote
Old 08-29-2009, 07:07 PM   #20
GSXRJJordan
Oh god, super fail. Thx DK.
Old 09-14-2009, 11:20 PM   #21
dkwasherexd
hahaa thx for he info.. Just that my stock ebrake no longer works and want to go hydro.. I will do this..
