Who makes an aftermarket rear lower arm set?
I just hit a really tall curb today and it screwed up my left rear lower arm pretty bad. I searched for some threads about aftermarket ones and couldnt find much. Im gona need them in the next week or so, so any info will help.
Hey Dude!
Damn you guys have been getting some hot weather! Email me some of that damned good water from the taps around the square will ya? I found this...looks good. http://www.zilvia.net/f/showthread.p...r+control+arms EDIT...err the hobnob at the end was a little uncalled for. at least Aaron stood his ground (as usual) As much as it sounds like a skipping broken record..amazing things happen with that big read button. I spend 75% more time on search mode than I do posting..and 850 posts in 3 months is a lot of labor...but hell..I am not bragging or complaining. Dude, I got to get up there this fall once the trees turn for some mountain driving. Did you ever get some cars and drivers located for a meet? I am hip. I love it up there.. Hit the ole search..I got hundreds of hits.. Cudos and laters... Bill Last edited by Bill Roberts; 08-18-2003 at 07:14 PM.. |
That is a front lower a frame is it not???
Looks like the lower A frame to me...well $hit, I never took all that crap apart yet...so is it on the left rear tire as your post indicated or left front? >>??? Last edited by Bill Roberts; 08-18-2003 at 07:19 PM.. |
Assuming it is an S-13 (you can navigate the site).
Here. http://164.46.112.185/NissanParts/Si...X/S13Index.htm |
WOW addicted
![]() Join Date: Dec 2001
I'm pretty sure the nismo units are just the stock units painted silver, with harder rubber bushings in them..
If you can get the stock one from PDM with poly bushes pressed in that would be better.
http://www.courtesyparts.com/nms/s13/s13_bushing.html
there are some arms that they won't sell just the bushing so they give you the arm with the pushing already in their from nismo. so i believe that this is just the nismo arm and bushing. If any body has ordered these before please correct me but thats how i understood the site. |
![]() Join Date: Mar 2002
sykikchimp,
Wasn't the Nismo LCA shaped a little different than the OEM LCA? I thought I saw a picture of a comparison on freshalloy. Can't seem to find it. I'll look after I get some rest. |
#14 |
![]() Join Date: May 2002
NISMO LCA is setup for lowered cars, the angle on ball joint is different probably some other differences over stock too
id get me a NAMS one one day..or Ikeya Formula!! >_< OOOH I WANT ONE SO BADLY! |
#15 |
WOW addicted
(pictures from PowerdBY007 on FA)
I think if he had them both at the same angle in this pic, it would have been easier to tell the difference.. It looks like a lot bigger difference than it is. On this one it looks like the ball joint is situated at a little differen angle. Even though I'm not sure how just changing the agle of the ball joint would affect anything. Personally, I don't think theres a difference except for the hard bushings, and the pretty paint job, and probably a little nice ball joint.
#16 | |
same goes up front with tie rod endlinks, that's why compnaies like KAZAMA make ones that are adjustable and can handle the changes from stock geometry im sure TRBeau (sp) can answer it better, he is knowledgable on such setups. |
#17 | |
![]() Join Date: Sep 2002
Keeping it Godzira bishes. So I murdered another turbo |
#20 |
oooh i forgot you have Kazama ones now (i hate you, give them to me)
as sykikchimp said AND the collar/spacer things, i was told is to adjust/eliminate bumpsteer! wooot! |
#21 | |
![]() no looking at the picture there are two black spacers just below the spherical bushing. theres also the length adjuster (gold collar) i was asking if the spacers on the bottom would be adjusted to comp for the car being lowered. i.e. removing or moving them from bottom of the bushing to the top etc etc... ![]()
#23 | |
#24 |
WOW addicted
moving the spacers from the bottom to the top would allow you to straghten the tie rod, which would eliminate bumpsteer.
That must be what they are for. Looks from the picture you could use an adjustment. ..DAMN.. this means I have to get these.... :hammer:
#25 |
that pic was taken during the install... i havent looked at it since the alignment... we'll play with them at Hyperfest. Russ wants to test a theory on them anyway so..
#26 |
![]() Join Date: Dec 2002
I heard my name mentioned. The Kazama tie rod ends have spacers to bring the tie rod further down, straightening out the angle that it has against the spindle. If you look at a severly lowered car, like mine, the tie rod end attaches at a 45 degree angle, and the tie rod itself sits at about a 15 degree angle, putting more stress on the rod end and causing it to wear prematurely.
For rear lower a-arms, NAMS makes a nice set, fully adjustable.
#27 |
ive seen the NAMS in person (rear a-arm)
OMG i jizzed myself. its sooo sexy. i wanted to buy it but it is WAY too much for me at the moment examined the WHOLE s13 NAMS lineup..wow. one day..one day.. |
#28 | |
#29 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
Stop making me want new control arms!
Heh. I'm actually looking to order some tein tie rods and ends.... Must reduce understeerrrr.... ![]()
#30 | |
unless you mean understeer as in not enough steering haha.. ![]() |
