Old 09-12-2009, 04:25 PM   #1
redsand100
redsand100 is an unknown quantity at this point
Question Crankshaft position sensor issues!!!!!!!!!
I have a 5 speed 94.5 240sx (this is a S14) and, the wire harness for the CKP sensor is missing. I need to know exactly where the two wires for the CKP sensor connect to. I was informed that they connect directly to the PCM in pin 53 for power and pin 50 for ground but, i don't know for sure. The pin 53 in the wiring harness for the the ECM is non-exsisting. I am also unsure if I have obd1 or obd2 because, I have both connectors. Can anyone help? [email protected]
redsand100 is offline   Reply With Quote
Old 09-12-2009, 04:55 PM   #2
projectRDM
projectRDM's Avatar
You can read the FSM, it'll tell you.
The subharness from the CPS to the lower harness has three wires, Is yours missing, or cut off? I'd source the subharness and wire into the lower harness, easier than running back inside.
FORMERLY R240NA
