#1081 |
I love this look so much. Im still having the worst time comprehending offset ideas, all things into account like clearing fenders/calipers/arms/coils without too much rolling pulling. I get that higher offset is further from center line or negative closer and so forth. Say i use this set up on an s13 coupe, 18x9.5 on all fours 245/35/18 F - 255/40/18 B. Getting to the point, would running a fair offset like +10 or so keep it flush upfront and in back? I've been using this http://www.rims-n-tires.com/info_specs.jsp to help visualize i still cant clear it up in my head haha
#1084 | |
![]() Join Date: Jul 2004
![]() ![]() ![]() ![]() Feedback Score: 8 reviews
* PigNose SMIC Grille/Vent P# 62697-44F00 * LMK What you guys got ![]() |
#1085 |
#1088 |
That guy was a total dickwad, he would completly cut across every corner to stay on my ass when I was already going slow due to traffic. I could hear him spin his one tire every turn too. I dont know about you guys but I dislike having a 6000lb truck tailgating me on a twisted mountain road.
I really want to shoot that fucking idiot in the face. He was a local too, so he should of known better. Just thinking about it totally pisses me off. It took all of 1 turn to loose the jerkoff when the road was clear though. |
#1091 |
doesnt solve much but its the jersey way of doing things... that and pulling up next to someone and yelling at them. some people shouldnt be allowed to drive.
arabtitalator: im running 245/40/17 upfront on an s13 and ur concern shouldnt be so much being flush on the outside as rubbing on the inside. 17x9+22 currently w/ 1-2mm clearance between the wheel and the lower spring perch on the coilover. |
#1094 |
![]() Join Date: Apr 2009
Trader Rating: (38)
![]() Feedback Score: 38 reviews
i got some 18x9 +22 and 18x10+25 advan rg2's just trying to get some opinions on tire sizes, i was thinkin about 275/35 and 295/35 think those will sit good on a stock fender s14? slight roll in the back, and lip pounded flat up front, also the car is really low.
#1095 | |
![]() Join Date: Jan 2003
![]() ![]() Feedback Score: 13 reviews
Looking at your width/offset for the front, I'd recommend nothing larger than a 255/35 in front if you are planning on using stock fenders with a roll, acceptable camber, clearing your suspension, and having next to no rubbing issues with the fender well. My personal experience with an 18x10 et+7 using a 255/35 was horrible...had to pull the fronts about an inch to make it look right, fender buckled blah blah so starting over right this time. I know gsracer had 18x10 +18 with a 275/35 at one point, so maybe he could chime in on that fitment. For the rear, I know from experience an 18x10 +23 with 255/35 cleared with room to spare with a roll/1 inch pull. However, you are planning on running a 295/35, so you'd have to do at least that to make it look right. I think with a small pull you'd have it looking perfect. Some people frown on a tire stagger that far apart in width (255/295) but I think you'd be okay especially if you are making good power...may have some understeer, so you could dial in minimal toe out/zero toe to avoid that. That may make it more twitchy though, especially in a straight line. What's your purpose for the S14? |
#1096 | |
Trader Rating: (38)
#1098 |
I need need need help with my wheel fitment, what do i need to do to make my wheels and tires fit. I'm on a very tight budget, and the front rub on my struts. I'm going to roll my fenders and run 8mm spacers in the front will this help at all? and also if it will help clear i have a pair of Kumho Ecsta 235/45/17 that i could run in front.
YOUR CHASSIS: s13 coupe WHEELS: Sportmax 006 17x9 +20 all around 4x114.3 TIRES: Kumho Ecsta 225/55/R17 all around MISC DETAILS: My stock KA24DE daily PURPOSE OF CAR: street on fresh KYB GR2's + Eibach sportlines all around
I drift, I drive, I jerk |
#1099 | |
BURN OUT IN YOUR FACE! 1998 S14 LS7/T56 swap in progress, build thread: http://zilvia.net/f/tech-talk/147301...d-gto-pan.html |
#1100 |
![]() Join Date: Aug 2005
A 225/55/17 is WAY too tall for any s-chassis.
A 235/40/17 is ideal for a 17x9 +20, and onyl requires a few (2-3)mm spacers in the front to clear some coilovers, so you wont even need to change studs or use bolt on spacers. Some coilovers dont even need a spacer with this size. Both 225/55 and 235/45 are way too tall.
#1102 |
![]() Join Date: Sep 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
Wheels
Work Equip Front : 17x9 +22 + 5mm spacer so effective +17mm Rear : 17x10 +22 Tires Front : 255/40/17 Falken Azenis Rear : 275/40/17 Falken Azenis ![]() ![]() ![]() ![]() ![]() I need to get some pictures of inner clearance and some better of the flushness, also I haven't had an alignment in a couple years and I've changed the suspension around twice now. I would imagine everything is close to being in factory spec. |
#1103 |
What wheels/tires are those on the miata?
#1105 | ||
![]() Join Date: Apr 2003
Trader Rating: (22)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 22 reviews
1997 Nissan 240sx SE(Rb25det+GT35r= 486whp on 93pump):http://zilvia.net/f/premium-member-b...oject-2-a.html Quote:
#1106 |
To answer your question the miata is running work ewings, 15x7 with a 205/50/15 azenis. A buddy of mine, has a heavily modded stock na motor miata, lucky if it could break 100whp. Luckily he's finally decided to boost it this winter.
Thanks Rick see you saturday, and good luck in the marathon! |
#1107 |
[quote=longfellow;2144654]YOUR CHASSIS: S14
WHEELS: 5 Zigen FN01r-C's (Hyper Black) 17x8 +25, 17x10 +12's TIRES: Falken Azenis RT615's; 235-40-17, 255-40-17 Suspension: KTS Coilovers 8K/6K springs, SPL front tension rods, SPL RUCAs, SPL Rear Toe arm's, Longfellow Fender braces, OEM Tie rods, ES Steering rack Bushings, SPL Subframe Inserts Brakes: Q45 front w/ OEM rotors, Hawk Pads,SPL SS lines; Z32 Rears, OEM pads, Rotors, SS lines Engine Mods: Modified stock intake, Home Made Exhuast MISC: Home made Brake deflectors, Recaro SRD, Personal Wheel, Stock VLSD, 15mil H&R Spacers(front) PURPOSE OF CAR: street/track/both PICTURES: -Old shitty tires & before leveled out ride height / current alignment / 15mil Spacers- ![]() ![]() Are you rubbing at all in the rear? Do you think you can fit a 265/40/17 rear tire? I was thinking of getting 17x10's with a +25 offset and running 265's. Do you have anymore pics I want to see if the rear tires are stretched. My suspension:koni/eibach pro-kit Thanks |
#1108 | |
Im getting the same wheels. I dont want to roll or pull any of my fenders. Can I run a 265/40/17 or even a 255/40/17 rear tire without rubbing? Suspension: koni/eibach pro kit |
#1109 |
I've been running 255-40 tires out back for over 2 years now. I have pulled fenders since my rear offset is sorta low and the rear tires are slightly stretched but its nothing serious. But you shouldnt have any problems on R33 wheels I dont think. I'd run 255-40's though if it were up to me since there are better tire options in that size. Your going to have to pull the rear fenders, there is no reason not to. Its stupid if you dont.
I run 255-40-17 NT05's on all 4 corners now. Look up at the top of the page this page and you'll see new pictures of the car. |
#1110 |
In time-out for misbehaving.
wheel question...
does anyone know why one side stick out further than the other?
my driver side sticks out further than my passenger side ![]() they both are same size and offset. pic: ![]() ![]() good passenger side: ![]() ![]() |
