Old 09-20-2009, 07:47 AM   #1
bigjacsoc
bigjacsoc is an unknown quantity at this point
SR Tial 50mm BOV Question
If I get a Tial 50mm BOV and I wanna run low boost like 7-11psi but then wanna turn the boost up to 15psi every once in a while would I need to get new springs or can I just get a 7psi spring and be able to run anywhere from 7psi-15psi?
bigjacsoc is offline   Reply With Quote
Old 09-20-2009, 08:40 AM   #2
Z33dori
Z33dori's Avatar
you need the 11 psi spring
if you go on Tial's site, they give you a chart for selecting the correct spring for your engine, not your boost.
generally sr's run 18-21in/Hg (vaccum) so Tial recommends their 11psi spring.
http://www.tialmedia.com/documents/w3_tial_bov50_sp.pdf
Old 09-20-2009, 09:07 AM   #3
bigjacsoc
Idk if it makes a difference but I have an S14 Kouki SR with T28. What's the vacuum on it or can you direct me to a site with it?
Old 09-20-2009, 09:33 AM   #4
Z33dori
Z33dori's Avatar
my buddy's S14 SR runs about -19in/HG
so it would still be the same spring
the only way it could really go up is if u have big cams
also the springs are inter-changeable
Old 09-20-2009, 01:19 PM   #5
bigjacsoc
Thanks, I know they are interchangeable but was just wondering how annoying it would be to have a Tial. I actually don't have it in yet I am just looking for an S13 hotpipe for my SMIC setup and if I can't get one used and have to get a new hotpipe and BOV I want it to be a Tial.
Aren't you on 240Atlanta.com?
50mm, bov, spring, tial
