Old 09-21-2009, 06:33 PM   #1
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
Best grease for poly bushings?
The issue is, the supplied grease with Energy suspension will grip the inner casing to the bushing, causing bind. The grease is not "slippery" enough to provide quick movement between the surfaces for daily driving. It is also too thick to remain inside the bushing when the inner casing is pressed into the bushing. Unless you make slots inside the bushing, all the grease usually gets pushed out when you push in the metal casing. Plus this stuff sucks, so aside from white lithium (which dries up), is there a super effective grease such as;
Synthetic brake grease
Synthetic marine grease
Moly grease used for transmissions?
I would assume the marine grease would be water repellant, the synthetic part means it would disclude petrolium, which eats poly bushings, but doesnt moly grease have a better sheer rating?
What are you using?
Bigsyke is offline   Reply With Quote
Old 09-22-2009, 02:06 AM   #2
let5l1de
let5l1de's Avatar
Trader Rating: (30)
let5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfectionlet5l1de is close to perfection
Feedback Score: 30 reviews
Send a message via AIM to let5l1de Send a message via Yahoo to let5l1de
Energy suspension has changed the lubricant supplied with their polyurethane bushings over the years. All the lubricant supplied has been sub-par in my opinion.
I have used the SuperLube brand
synthetic NLGI Grade 2 heavy-duty, multi-purpose lubricant with PTFE. Durable enough to stick, withstand the elements quite well in exposed suspension components and provide decent lubricity to combat those squeaks.
Hot-rod guys drill small holes within the bushing to form pockets that retain the lubricant/lubricity and reduce friction. Be careful not to remove too much material as you may change the durability and characteristics of the bushing.
~m
**GR Performance facebook** Pics & More! Comments! http://www.facebook.com/pages/GR-Performance/120477531339202
Read My Sales Review
626 Friday Nights San Gabriel
let5l1de is offline   Reply With Quote
Old 09-22-2009, 02:19 AM   #3
GSXRJJordan
GSXRJJordan's Avatar
I use a synthetic moly grease made by Motul. It's super cheap, and awesome - originally started using it racing bikes, since every motorcycle racer I know uses this stuff, and motorcycle guys are WAAAAAY more anal about 'sticktion' (resistance to initial movement) and wear characteristics than any car guys I know.
MOTUL Tech Grease 300
I get it at WestCo Nissan for $5, btw. Perfect consistency, great wear, and poly-safe.
Old 09-22-2009, 05:14 AM   #4
red240
red240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the rough
many years ago I put bushings in that were supposed to be impregnated with graphite and not squeek, but they did after a short while
So I drilled them and installed zerk fittings and pumped them full of Lithium grease, end of problem LOL!
red240 is offline   Reply With Quote
Old 09-22-2009, 04:00 PM   #5
Bigsyke
Bigsyke's Avatar
That sounds awsome.
Im using syn brake caliper grease right now, but its far from tacky.
