Old 08-25-2003, 02:32 PM   #1
AlligatorBling
AlligatorBling's Avatar
AlligatorBling has made poor choicesAlligatorBling has made poor choicesAlligatorBling has made poor choicesAlligatorBling has made poor choicesAlligatorBling has made poor choicesAlligatorBling has made poor choicesAlligatorBling has made poor choices
Send a message via AIM to AlligatorBling Send a message via Yahoo to AlligatorBling
Changing ALL fluids in my car
Ok, i wanna change it all, the ultimate tune up. the whole shabang. brake, power steering, trans ect... along with new plugs and wires. what id like from you guys is some advice on the BEST performance brand fluid for each fluid change for the car. and a good set of plugs and wires.... Also... does anyone know where I could find all the proper fluid levels? Thanks for you input!
AlligatorBling is offline   Reply With Quote
Old 08-25-2003, 02:46 PM   #2
Dousan_PG
Dousan_PG's Avatar
dood use the search mode, we cover various fluids monthly
search indiviually
brake fluid
tranny fluid
diff fluid
ps fluid
etc..
Aaron
Pink GodziRa
Old 08-25-2003, 09:32 PM   #3
old_s13
old_s13's Avatar
old_s13 is an unknown quantity at this point
see fsm
old_s13 is offline   Reply With Quote
Old 08-26-2003, 04:58 AM   #4
AlligatorBling
yes i could use the search, and look. and look. and look. and get treads of arguments, topics sort of what im looking for... ect
or.......... one of you kind souls could give me a quick list. and i would be soooo grateful please?
Old 08-26-2003, 08:30 AM   #5
uiuc240
uiuc240's Avatar
uiuc240 is an unknown quantity at this point
Send a message via AIM to uiuc240
It all depends on what you want to spend. If you want the best (most money), get Amsoil for the motor and the gears, and throw some Motul in the hydraulic lines.
Get NGK plugs and wires...they're that good. Platinum if you want, but copper is all you need.
Gears: Amsoil Series 2000 75W90 gear lube
Motor: Amsoil 5W30 full synthetic
Brake Fluid: Motul non-race fluid...make sure it's DOT 3, 4 or 5.1...not 5
Power Steering Fluid: Amsoil ATF DEXRON III
Coolant: Dunno...Prestone works just fine...buy distilled water to mix
OK, now it's time for you to do a little searching on your own bro. I just told you what I would buy (well, actually, I'd just get Valvoline brake fluid...or Castrol GTLMA if you can find it). And any brand of ATF will be fine for the steering too. I have Mobil 1 ATF in mine.
Eric
2002 Mazda Protege5
1989 S13 w/SR20DET (sold)
uiuc240 is offline   Reply With Quote
Old 08-26-2003, 10:57 AM   #6
AlligatorBling
thankyou
