Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Suspension
Old 10-02-2009, 02:28 PM   #1
Ravspec
Ravspec's Avatar
Trader Rating: (25)
Ravspec is just really niceRavspec is just really niceRavspec is just really niceRavspec is just really niceRavspec is just really niceRavspec is just really niceRavspec is just really niceRavspec is just really niceRavspec is just really nice
Feedback Score: 25 reviews
Send a message via AIM to Ravspec
Exclamation Buddy club Racing Spec Damper Kit
#BC02-RSD89S13PM
Buddy Club Racing Spec Damper Kit S-13 89-93 with mounts.
Or
#BC02-RSD94S14PM
Buddy Club Racing Spec Damper Kit S-14 94-98 with mounts.
Both in stock and ready to ship to any lower 48 States for $1375
COMPLETE SUSPENSION KIT
"Racing Spec Damper" is the perfect complete suspension kit with resemblance of P-1 racing damper's excellent designs while it is de-tuned for street - circuit use. However, the car specific pillow-ball upper mount design, proper spring rate, 15 level damper adjustment, and height adjustment capabilities accommodates driver's requests.
DEVELOPED WITH 15 YEARS OF VALUABLE RACE DATA
Racing Spec Damper Kit is a high performance sports suspension kit designed by engineers using a vast quantity of data that Buddy Club has accumulated in the past 15 years using its high performance aluminum damper (ie. spec 30.1 Racing Damper) on various racing cars and tuned cars, focused more on the proper damper size, spring rate, dampening, stroke length for customer's use in winding roads and race tracks.
1. Adjustment bracket
With an adoption of a "adjustable bracket" the ideal low postion can be achieved without any use of helper spring. One rotation, approximately 2mm, will enable the user to change the length of the damper. Dampers are black plated rather then painted for extra durability.
2. 15 Level Adjustment
The 15 level adjustment corresponds to variety of racing stages, from Touge 'mountain roads' to cicuits. Adjustment is easy with its click adjusting dial. The dial is located ither on the upper shaft for regular dampers or on the lower shaft for inverted dampers. This damper is also designed for town use; hence, dampening setting ranges from hard (+4kg/mm) to soft (-4kg/mm).
3. Single tube type shell case
Unlike visual based cartridge damper, adoption of the single tube shell case enables the use of wishbone type 46 and strut type 36. This leaves an extra space for larger pistons. Also this change allows for better heat dissapation, which prevents performance deterioration from hard runs. Special steel and anti-friction components are used to minimize friction.
4. Specialized Pillow-Upper Mount
Application of the upper pillow upper mount allows you to have greater handling response, by minimizing upper chasis movement. Caster adjusment allows the correction of camber for further tuning ability. Caster adjustment plates are not included on all applications.
5. Spring seat / lock seat
Each single full rotation equals 2mm drop. The adjusting locking seat allows for spring stress to adjust with out the necessity to change suspension position.
6. Original spring
Tremendous enhancement in durablity resulted from a high quality surface processing. Constant testing resulted in a perfect spring rate for each application. S13 and S14 8K/6K.
Thank you.
Ravspec is offline   Reply With Quote
Old 10-13-2009, 12:56 PM   #2
Ravspec
Ravspec's Avatar
Trader Rating: (25)
I can still Offer BC Racing Coil Overs for $1000 shipped with a free Strut bar.
