Old 10-30-2009, 04:46 PM   #1
z2roll4life7
z2roll4life7's Avatar
z2roll4life7 is an unknown quantity at this point
Stock Sr's Run 11 Psi from the Factory.....
Also i Though U place the EGT sensor on to the Manifold before the Turbo?
like about 2 to 3 inches from the head on the 3rd or 4th runner You have a tomei Manifold put a Bung on that u should get a better reading
z2roll4life7 is offline   Reply With Quote
Old 10-31-2009, 12:51 PM   #2
dongoesby
dongoesby's Avatar
dongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of lightdongoesby is a glorious beacon of light
i placed the egt sensor after turbo actually. I tapped a hole on the dp where it was like right next to turbo (less than 1 inch away).
i know on the manifold would give more accurate reading, but really don't want to make a bung on the tomei...
any thoughts on the gauge readings?
dongoesby is offline   Reply With Quote
Old 10-31-2009, 02:07 PM   #3
ILoveJDM
ILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to behold
hes talking about vacuum
ILoveJDM is offline   Reply With Quote
Old 11-01-2009, 12:30 PM   #4
z2roll4life7
He was talking About PSI when he was on the Highway hes over 10 psi (Sr from the Factory is at 11 Do your Fucken Research) and hes at 1500 THATs FUCKEN hott the placement of the EGT sensor can have a big effect all i can say is the Right way would to put in on ur Manifold bro also Check Ur Timing
Old 11-01-2009, 12:59 PM   #5
dongoesby
dongoesby's Avatar
actually no. Honestly, i appreciate your help for chiming in. But, like lots flame going on now on new zilvia users, please use commas and punctuations...
stock sr t25/t28 does run 7psi without mods, but given the factory boost solenoids are still hooked up, it would go up to 11psi depending on the rpm. It could be another topic for this, but it is not the matter here anyways. I use hks actuator and it holds steady 14psi under WOT. And the egt shows 1500 deg F only at 14psi. When I'm at half throttle (around 11psi), the egt would be around 1400 deg F. And under no boost, cruising at 70mph all motor, the egt is at 1200 deg F.
Any ideas?
Old 11-01-2009, 04:19 PM   #6
jr_ss
OP, glad you answered most of your own questions. In my personal opinion, I'd back down the psi levels until you get a tune to make it safe..
That's right the wastegate does pop off at 7psi, the boost solenoid, not the restrictor allows the boost to creep to 11. That is not 11psi all the time, nor the stock pressure. Therefore, the factory boost setting you'll see is 7psi on 99% of STOCK swaps.
