Old 08-12-2008, 03:13 PM   #31
SlideWell
SlideWell's Avatar
SlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfection
the optional 3 din gauge cluster for the kouki s14 SR reads boost up to .7 bar. and yes, T28 for all s14 SR's.
SlideWell is offline   Reply With Quote
Old 08-12-2008, 03:15 PM   #32
!Zar!
!Zar!'s Avatar
7lbs no solinoid. Which is almost .5bar.
Old 08-12-2008, 03:24 PM   #33
slidingsky
slidingsky's Avatar
slidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfection
I'm still getting mixed signals but most of them say that the boost pressure itself is 10 PSi +/- .5psi for the S13/14 SR
Which would be more reasonable compared to the Avenir.
slidingsky is offline   Reply With Quote
Old 08-12-2008, 03:31 PM   #34
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Feedback Score: 40 reviews
What I found on the Avenir was threw a japanese translation.
‚ª‚ñ‚΂êƒAƒxƒj[ƒ‹
ブースト
ノーマル(0.65)。EVCぐらいは付けたいかな?
Translated:
"Boost Normal (0.65). As for about EVC the kana which we would like to attach?"
Old 08-12-2008, 03:34 PM   #35
s13silvia88
s13silvia88's Avatar
s13silvia88 is an unknown quantity at this point
its for response. with my friends with out the boost solenoid there cars lag in response and boost comming on fast. or early in the rpms. i connected it rite bc i had a front clip and i kno wat wires were connected to it so u jsut extend it...
s13silvia88 is offline   Reply With Quote
Old 08-12-2008, 03:53 PM   #36
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
It not strickly for responce, however it may help improve responce, but if you were to look closely at the wastgate signal line, inside of it you will find what is called a restrictor pill, this delays the on-rush of incoming air briefly to alow boost to get a head start before being bleed off to maintain targer boost pressure, this lil pill have a big influence on precieved lag.
Old 08-12-2008, 04:19 PM   #37
SoSideways
SoSideways's Avatar
Those pills are like the holy grail of boost control on the twin turbo Z32s.
Old 08-12-2008, 04:27 PM   #38
Sileighty_85
Sileighty_85's Avatar
Ok Well I can confirm that the Stock boost pressure for the S13 SR20DET is .7 Bar
I'd like to upload the video but there is like 2 mins of crap until the I show the Boost gauge.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 08-12-2008, 11:50 PM   #39
nismo_s14_
nismo_s14_ will become famous soon enoughnismo_s14_ will become famous soon enoughnismo_s14_ will become famous soon enough
i read and was told:
s13 sr is @ 7psi
s14 sr is @ 8psi
s15 sr is @ 10psi
nismo_s14_ is offline   Reply With Quote
Old 08-13-2008, 09:10 AM   #40
Silverbullet
Silverbullet's Avatar
Silverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really nice
Send a message via AIM to Silverbullet
^ you obviously don't read.
i find it a little hard to believe the stock S14 was able to adjust to 10psi on a T28 from the factory. That yields roughly 250whp.. close to maxing injectors.
HouseBuyers365.com
Originally Posted by Flybert
Go back to whatever Honda forum you came from.
Silverbullet is offline   Reply With Quote
Old 08-13-2008, 10:45 AM   #41
kernel
Trader Rating: (28)
kernel is an unknown quantity at this point
Feedback Score: 28 reviews
I can confirm the stock boost pressure is 7 PSI with this solenoid hooked up.
Both my RHD (180sx 1991 and Silvia 1991) were boosting that and everything was stock.
180sx had a FMIC with cat-back, silvia had cat-back only. That's all.
kernel is offline   Reply With Quote
Old 08-13-2008, 11:43 AM   #42
Sileighty_85
are you sure its 7psi and not .7 Bar?
My 180SX was bone stock with ONLY a cat back and ran .7 BAR
dont forget about the pressure drop you will encounter when using a FMIC
後輪駆動車1番
1986 SR86 - 200ish
Old 08-13-2008, 12:01 PM   #43
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Again not doubting you that you have it hooked up, but maybe your solenoid doens't work but this goes against having a boost solenoid in the first place if your only seeing 7psi because the wastegate alone will manage a 7psi boost pressure.
Old 08-13-2008, 01:31 PM   #44
s13Eper
s13Eper's Avatar
s13Eper will become famous soon enoughs13Eper will become famous soon enoughs13Eper will become famous soon enoughs13Eper will become famous soon enoughs13Eper will become famous soon enough
Just a side note, I have a switch wired between the factory boost control solenoid and the ecu. Closed (on) = around 11psi, open (off) = around 7psi. Stock red top.
s13Eper is offline   Reply With Quote
Old 08-13-2008, 02:19 PM   #45
kernel
Trader Rating: (28)
I have Defi gauges in both my car and it was .5 Bar
Also, I can't confirm that both solenoid were working but I'm sure I had 7 Psi, no more.
I can confirm that the spool up time was higher without the boost solenoid, I hooked up my actuator directly to the hot pipe and it was a bit slower !
The silvia had SMIC...so...no pressure drop there and still 0.5 bar !
Old 08-13-2008, 04:40 PM   #46
Def
Originally Posted by UNISA JECS View Post
When you think about all this:
KA24DET @ 7psi has an effective compression ratio of 14.0:1
SR20DET @ 7psi has an effective compression ratio of ~12.5:1
SR20DET @ 9.7psi has an effective compression ratio of 14.0:1
This shows one example why it takes more boost on a SR to make the same horse as the KA all things equal.
Factory boost pressure has to be similar to the Avenir SR20DET from the factory.
Effective compression ratio is an essentially meaningless number. At least mechanical compression ratio gives you a very rough idea of the ideal thermal efficiency achievable according to the Otto cycle.
A better way to look at the two engines under boost is to calculate the mass of air per cycle at an arbitrary volumetric efficiency.
As for stock boost, I made 205 rwhp with just a turbo back exhaust and stock everything else on my redtop with a T25 at 7.5-8 psi(wastegate spring). I can't imagine stock boost is much higher than that with the BC solenoid if 205 bhp is to be believed.
Old 08-13-2008, 05:14 PM   #47
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
I dunno, the stock S13 sr20det only has a ~2.25" Dp and 2.25" catback and stock air box so 205ps at .7bar doesn't sound unreasonable but .5 bar might. Ofcourse overhere we usually larger exhaust and intakes so at .5 bar we make what they make at a higher pressure.
Old 08-13-2008, 06:11 PM   #48
Def
I'd expect more like 170-175 rwhp if it was actually 205 bhp. I find it hard to believe you'd get a 30 rwhp gain from just an exhaust and the slightly bumped boost that comes with it, but I guess it's not completely impossible.
Old 08-13-2008, 06:38 PM   #49
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
couldve sworn it was 11psi
who cares tho, stock boost sucks
ho ha ho chi chi
koukimonster139 is offline   Reply With Quote
Old 08-13-2008, 06:46 PM   #50
Def
All I've got to say if it's 11 psi, is I feel sorry for those with stock S13s/S14s, as the SMIC takes about 2 seconds of WOT to heatsoak at about 10-11 psi on a T25.
I got nasty detonation on the track with 93 octane, stock everything except the turbo-back exhaust and 8 psi. After 1 lap the SMIC was essentially something good to cook an egg on, that's about it.
Old 08-13-2008, 07:25 PM   #51
redclaw05
redclaw05's Avatar
redclaw05 is a glorious beacon of lightredclaw05 is a glorious beacon of lightredclaw05 is a glorious beacon of lightredclaw05 is a glorious beacon of lightredclaw05 is a glorious beacon of lightredclaw05 is a glorious beacon of lightredclaw05 is a glorious beacon of lightredclaw05 is a glorious beacon of lightredclaw05 is a glorious beacon of lightredclaw05 is a glorious beacon of lightredclaw05 is a glorious beacon of light
Send a message via AIM to redclaw05
im rocking a SMIC. running 7 or 8 psi according to my profec B.
stock t28 as well.
hoping to get a FMIC very soon so it can feel the breeze
1995 S14 NonSunroof.
redclaw05 is offline   Reply With Quote
Old 08-14-2008, 12:17 PM   #52
asiandude15
asiandude15 is an unknown quantity at this point
Alright we hooked up an autometer guage to my friends car and he has a S14 (from a k's aero) sr20det in his S13. The guage said 5lbs. I was like WTF?!?! Any ideas why cuz the guage is hooked up before the FMIC cuz I wanted to see a direct reading without the pressure drop and I would imagine with the pressure drop through the FMIC setup, if it is really at 5lbs than that would mean like 3-4lbs by the time it gets to the throttle.... Weird
asiandude15 is offline   Reply With Quote
Old 08-14-2008, 12:24 PM   #53
SoSideways
SoSideways's Avatar
Your wastegate actuator could be tired and on its way out.
Old 11-01-2009, 05:57 PM   #54
jssilc
jssilc's Avatar
jssilc is an unknown quantity at this point
i kno this is a old thread but interesting. did you guys ever think the bc could be used to keep the boost consistant. im on stock wastegate on a t25 but on a ka now 4-5gear the boost kinda doesnt stay consistant maybe the bc is ment to keep the boost consist through different conditions.
jssilc is offline   Reply With Quote
Old 11-01-2009, 06:06 PM   #55
TurboStrong
TurboStrong's Avatar
TurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really nice
My stock notch top is stock and she hits 7 pounds.
TurboStrong is offline   Reply With Quote
Old 03-22-2010, 12:26 AM   #56
Mesarina
Mesarina's Avatar
Mesarina is an unknown quantity at this point
Old thread I know, but just to clarify I have a stock jdm 94 180sx (black top) with boost solenoid, and stock boost is 7psi, no more, maybe you guys doing swaps got an engine with a shimmed wastegate or something...
Mesarina is offline   Reply With Quote
Old 03-22-2010, 01:52 AM   #57
cotbu
cotbu's Avatar
You with only a post count of ten...should do some test. like remove the solenoid from the equation, then log boost if it's 7psi ask yourself what's wrong with this?
unrelated, I have friend that says he was running 10psi. He was actually running 20+ on an s14 bb turbo with 370's. When he looked at his gauge it was 10psi. I don't doubt that. When I looked at the gauge it was 20, then by 6900rpm it was 10psi
your solenoid is probably not functioning or the ecu is detecting something (like over boost) and turning off the solenoid.
Old 03-22-2010, 09:11 AM   #58
Mesarina
Mesarina's Avatar
Post count doesn't have anything to do about how much me or you know about cars, I have code 55 on my ecu, I already removed the solenoid from the equation too, hope your friend's s14 is not running 20psi with 370cc injectors
Old 03-22-2010, 10:25 AM   #59
cotbu
cotbu's Avatar
Sorry about the post count thing, It's not what you think. He has an s13 with an s13 sr20 and a s14bb turbo.
You on the other hand bumped a thread with out documenting your proof that the solenoid gives you 7psi. I no longer even think about testing this theory, since i dumped the solenoid a while ago. If someone, such as yourself does have the solenoid and can document it keeping boost at 7psi or allowing boost to reach 11psi, would put an end to this age old question.
Old 12-31-2016, 12:31 PM   #60
Solus Christus
Solus Christus's Avatar
Solus Christus is an unknown quantity at this point
I have a stock S13 Silvia K's and my boost gauge reads 11 psi with boost solenoid.
I'm guessing a motorswap without the boost solenoid will default to the wastegate's 7 psi but a stock JDM Silvia/180 with the solenoid can reach 11 psi.
Solus Christus is offline   Reply With Quote
