Old 11-10-2009, 10:41 AM   #1
GunmetalSR
GunmetalSR is an unknown quantity at this point
god bless it and she ran soo good
ok so last night i was driven the s14 home from a friends house on the i10 and i went up a bridge..well ya know how the base of the bridge is kind of a bump well i jumped up about an inch of the ground and ass soon as that happened my car lost all power...everything electronic was working but my car jus slowed down as i hit the gas peddle as if the motor wasnt even on but was in gear....i got to the side and tried to start my car and it wouldnt start it jus turned over and did nothing and i tried again a minute later and it sounded like it was on 2 if not 1 cylinder...i doubt i blew my head gasket and i wasnt actin like an ass wit the car and im stumped
im obviously gettin gas bc as i tried to start it was and i could smell gas comin out the exhaust and i could hear my fuel pump
i checked all my fuses and my wire harness in my fender well and nothing is wrong so i hav 2 choices(spark or compression)
im scared shitless that i hav no compression
i need help asap so someone please shed some light
GunmetalSR is offline   Reply With Quote
Old 11-10-2009, 09:49 PM   #2
BIGGJERRYC
BIGGJERRYC is an unknown quantity at this point
im sure you have compression and all that. I would check your grounds and stuff. make sure your wires are all on and such. also if you have a stereo system and a fuse in line with the amp cable... they come loose once in a while and cause instability in the electronics
BIGGJERRYC is offline   Reply With Quote
Old 11-11-2009, 09:54 PM   #3
GunmetalSR
thanks ill check around
i found out i was getting very little spark so im thinkin dissy
Old 11-12-2009, 02:30 AM   #4
jr_ss
Sr's don't have distributors... It's either a loose connection somewhere or your ignitor/CAS took a shit, but I think the CAS is highly unlikely to go dead from a bump.
Old 11-12-2009, 03:12 AM   #5
Om1kron
Om1kron's Avatar
Originally Posted by jr_ss View Post
TURBOSr's don't have distributors... It's either a loose connection somewhere or your ignitor/CAS took a shit, but I think the CAS is highly unlikely to go dead from a bump.
Just thought I would fix that for you.
Wayne Edwards
https://om1kron.blogspot.com
Old 11-12-2009, 12:21 PM   #6
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
I don't understand the title of this thread but oh well. I would definitely check all electronics, do you know if you bottomed out?
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 11-14-2009, 07:29 PM   #7
GunmetalSR
i hav a ka
i made my name a long time ago when i liked sr's
ive gotten in the habit of sayin god bless instead of god dammit and the day the 240 died on the interstate it was runnin really really good
anyways im getting spark jus not alot so im thinkin dizzy
i hav a new one but i keep puting the install off
(im really lazy lol
Old 11-14-2009, 07:34 PM   #8
Def
I had the ECS(whatever they call power to the ECU/fuel pump circuit) relay die on my S13 when I hit a pothole in downtown Atlanta. Kinda sucked because I was trying to push it up a slight incline by myself as all these homeless guys were milling around.
Had similar symptoms, no power on the affected circuit, and all fuses were fine.
DEFSPORT
Old 11-14-2009, 08:58 PM   #9
GunmetalSR
well lemme ask u this
would it crank over at all
at first my car cranked over but was runnin on 2 cylinders
thanks though ill check that relay
Old 11-14-2009, 09:37 PM   #10
modulation
modulation is an unknown quantity at this point
If you're lower then check your wire harnesses in the front wheel well fenders.
If your car is running on two cylinders find out if you're getting spark on those cylinders.
Do all electronics (lights, radio, brake lights, etc) work?
modulation is offline   Reply With Quote
Old 11-15-2009, 10:04 AM   #11
GunmetalSR
thats the kick though all the electronics work and all my fuses are fine and my wire harness is uncut
verything is fine but im not gettin much spark which is why i say dizzy
Old 11-15-2009, 10:39 AM   #12
Ceepo
Ceepo's Avatar
check your cap and rotor, my ka when i had one ran like shit/ didnt want to run i cleaned those and it ran awesome, i would check grounds to nissans have a bad grounding problem...
Old 11-15-2009, 11:29 AM   #13
ryguy
ryguy's Avatar
ryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfection
x2 on the cap and rotor, I've had the screw come off the distributor before so it wouldn't spin.
ryguy is offline   Reply With Quote
Old 11-15-2009, 11:41 AM   #14
jr_ss
I assumed it was turbo. I know N/A's have a distributor, but who goes through the effort to put a weaker motor than the KA in?
Old 11-16-2009, 02:26 PM   #15
GunmetalSR
exactly right
anyways i swapped my dizzy but my battery is dead so ima see if i can get it charged today and see if itll run
Old 11-16-2009, 10:22 PM   #16
GunmetalSR
she lives...kinda
i found out that toyota 4 runners hav the positive and negative on opposite sides as the 240 so i blew mos of my fuss but dammit tha bitch started up the first try
i forgot that i took my exhaust off so i jumped like 10 feet in the air when i started her up
