Old 11-15-2009, 05:37 PM   #1
Luz Solar
Luz Solar is an unknown quantity at this point
How to lower a s14 fuel tank
I searched this and didnt find anything. I want to lower my fuel tank to locate a small fuel leak that can be seen coming from the top of the fuel tank. When I jacked the car up, I saw that the fuel tank sits on top of the diff. and other rear suspension components they might have to be removed. So I was wondering if the fuel tank could be lowerd with out it being to labor extensive or if I should just take it to a shop and avoid a big headach.
Thanks
Luz Solar is offline   Reply With Quote
Old 11-15-2009, 07:01 PM   #2
Ceepo
Ceepo's Avatar
Have you checked behind the back seat under that panel for leaks, there is a o ring on top of the tank that can leak after time(sometimes) i would check that out along with the fuel likes going into the tank at the top of it before i would start dropping the tank... just a thought...
Old 11-15-2009, 09:40 PM   #3
projectRDM
projectRDM's Avatar
Drop the subframe.
Drop the fuel tank.
There's no other way to do it.
FORMERLY R240NA
Old 11-16-2009, 10:11 AM   #4
Ceepo
Ceepo's Avatar
while you drop the subframe do new subframe bushings or the aluminum inserts
Old 11-17-2009, 07:41 AM   #5
Ali 556
Ali 556 is a well-known jackass
Originally Posted by projectRDM View Post
Drop the subframe.
Drop the fuel tank.
+1 the only way to do it
FUCK inserts,
Go Solid Bushing or don't bother to do it
'95 S14 Se With HKS's - BREMBO's - ES/SPL.
Ali 556 is offline   Reply With Quote
Old 11-18-2009, 11:02 AM   #6
ka-titties
ka-titties is an unknown quantity at this point
Originally Posted by Ali 556 View Post
FUCK inserts,
quoted for the truth
ka-titties is offline   Reply With Quote
Old 11-18-2009, 11:06 AM   #7
Ceepo
Ceepo's Avatar
Thats what i ment lol...
