![]() Join Date: Sep 2004
SR20DET Running REAL Rich
I have replaced the heat temp sensor, checked the MAF and changed the fouled plugs. but for some reason the car is still dumping fuel and running really rich. If I get the car up to speed and keep it in boost it will run with no problems. but when the engine is not under a load it will stall and then not crank back. The original problem was it would not idle long enough to get the engine hot - therefore I checked and replace the heat temp sensor, checked and replaced the fouled plugs. I am almost certian that the MAF is working. The only other thing that I can think could be a problem is an O2 sensor - although functional - may be covered in soot and not reading.
Opinions? Thanks Jh |
![]() Join Date: Aug 2008
What modifications have been done if any? s13 or s14sr? Check your injectors make sure they click and that they are not stuck opne. Also check to make sure the little o-rings or grommets are intact they could be leaking fuel from the rial rightn into the cyclinders.
#3 | |
1993 Nissan 240SX, Jamie Holladay Photography, Gadsden, Alabama, 180SX, I'll take another look but we have checked the injectors. |
![]() Join Date: Mar 2006
Holy god that car is modded.
Did you do all of it yourself, or buy it off someone? EDIT: Just saw you are running ACT HDSS with that setup.......how in God's name is it not slipping? I was (sometimes) slipping that same clutch kit with only 300 ft-lbs at the wheels......
Daily driven |
#5 | |
![]() Join Date: Jan 2008
![]() ![]() ![]() ![]() Feedback Score: 9 reviews
My car is running rich also my car isn't modded as much as the op's car
Redtop sr20det(stock, brand new rebuild maybe 1000 miles) Full turbo back exhaust, megan elbow/downpipe, buddyclub spec 2 FMIC/mishimoto, isis piping, hks bov(non recirc) 1995 s14
TW: http://zilvia.net/f/cars-sale/390459...d9s-coils.html |
