#31 | |
![]() Join Date: Jun 2007
Trader Rating: (22)
![]() ![]() ![]() ![]() ![]() Feedback Score: 22 reviews
There are 2 pins inside, you must get the OEM NISSAN Part #J4440-F53-TPA3. Use this tool to open the box and you will see 2 round connectors with gray protective caps that require a 2.5mm socket to remove. Under the protective caps you will find the connectors colored red for positive charged electrons and Black for negative charged electrons. Next you will need NISSAN Part#J4440-F53-TP5, this tool will allow you to charge the unit with special type of electrons, you will have to charge this exactly for 2 hours 25 minutes and 44 seconds to assure proper capacity of electrons have traveled into the device, once that is complete you can press the little red button and the device will self close and beep 2 times with a long tone to alert you that it's on and it will self close in 5 seconds , fallowed by a short single beeptell to tell you it's back online and operating. Do this with caution, these devices have tremendous amount of force when they close, somewhere around 500 pounds of pressure, so it could hurt you. If you need somebody to fix it for you I charge $155 for the repair |
#32 |
Lets not post whore here, the block does nothing. Do an experiment, drive the car around the block with the box, then remove it and do the dame thing. Nothing. My s14's damper was different.
I couldnt imaging how a solid peice of steel would dampen a firewall, rubber usually acts like a dampner, and even the dampner on the automatic tranny does jack shit. Theres no leverage on these pieces. Last edited by Bigsyke; 10-02-2009 at 06:26 PM.. |
#33 | ||
AFC #1
![]() Join Date: Oct 2003
#35 | |
![]() Join Date: Jan 2007
![]() Feedback Score: 8 reviews
