Old 11-21-2009, 07:38 PM   #1
TurboStrong
TurboStrong's Avatar
TurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really niceTurboStrong is just really nice
Blitz bov
i just added my blitz bov to my hotpipe, and i have a problem the blitz only blows off on high ass rpms, and on lows rpms between shifts i compresser surge?
is this normal?
TurboStrong is offline   Reply With Quote
Old 11-21-2009, 07:55 PM   #2
^fraktal^
^fraktal^'s Avatar
^fraktal^ will become famous soon enough^fraktal^ will become famous soon enough^fraktal^ will become famous soon enough^fraktal^ will become famous soon enough^fraktal^ will become famous soon enough
the adjustment nut should be just tight enough to not leak at idle. otherwise everything else is pretty much out of your control.
^fraktal^ is offline   Reply With Quote
Old 11-22-2009, 11:16 AM   #3
burnsauto
burnsauto's Avatar
If its just a few lbs thats its surging at (like 2-3) I really wouldn't worry about it TOO much. Just take some time to fine tune the adjustment on it. drive it around and see how you like how its reacting. Also, just make sure you dont have a vacuum leak..that can make a BOV lazy.
Old 11-22-2009, 02:33 PM   #4
TriniTT
TriniTT is on the path to ruinTriniTT is on the path to ruin
I'm having the same exact problem with mine and I'm trying to search to figure out what the problem is. I've adjusted it all the way out and it makes no difference. I've been told to find a looser spring, but I'm not sure where to get one other than from Blitz directly.
TriniTT is offline   Reply With Quote
Old 11-22-2009, 05:40 PM   #5
Om1kron
Om1kron's Avatar
the blitz bov is just kind of shitty imo... I have it pretty soft and the boost leaks out at 6000rpm, but at full stiffness it blows off once I'm at full boost, but anything below it surges, to be quite honest I would be happy just eliminating the bov. seriously it's just a t25.
Wayne Edwards
https://om1kron.blogspot.com
Old 11-24-2009, 07:42 PM   #6
TurboStrong
I just tightend the nut all the way and its still doing it.
and also when im in high boost i hear a loud hissing as well.
Old 11-24-2009, 08:11 PM   #7
Psycho 240 Freak
Psycho 240 Freak is making his/her stupidity well-knownPsycho 240 Freak is making his/her stupidity well-knownPsycho 240 Freak is making his/her stupidity well-knownPsycho 240 Freak is making his/her stupidity well-knownPsycho 240 Freak is making his/her stupidity well-known
I have the same issue with my Blitz BOV as well. Loosen it up too much and the engine will stumble between shifts. Tightening it up a bit more and you get surge under low boost. I've come to just accept the characteristics of an atmospheric bov and a maf. I thought about going with Synapse, HKS, or recirculating, but I've also seen those people have the same issue as well. I blew my old turbo which was a used HKS GT2530, but I think that's due to constantly pushing 20 psi rather than the bov. The turbo's been beaten on a lot before I got it too. I've had family members who run with some surge at low boost for years and their turbos are fine. I'll eventually recirculate my bov to see if it helps out though.
Psycho 240 Freak is offline   Reply With Quote
Old 11-24-2009, 09:01 PM   #8
TurboStrong
damn thanks for the info^^^^^
shoot anyone got any solutions for this problema?
Old 11-24-2009, 09:41 PM   #9
Om1kron
Om1kron's Avatar
either get a different blow off valve or just stop running one. I don't hear of a lot of people running Tial wastegates but full race loves them. I am really partial to them although they're fucking huge.
Wayne Edwards
Old 11-25-2009, 09:31 AM   #10
slider2828
slider2828's Avatar
THis is like super old news guys. Blitz was always known to leak hands down.... There really isn't a fix, but what I might try is to remove the paper gaskey between the bov and the pipe and use rtv.... Try also different heavy duty screws that won't stretch.... Its amazing to me 20 psi blowing outta the thing held down by two little screws...
Turn and Burn!
Old 11-25-2009, 10:07 AM   #11
Chops@MVP
Chops@MVP's Avatar
Chops@MVP is just really niceChops@MVP is just really niceChops@MVP is just really niceChops@MVP is just really niceChops@MVP is just really niceChops@MVP is just really niceChops@MVP is just really niceChops@MVP is just really niceChops@MVP is just really nice
Send a message via AIM to Chops@MVP
The Blitz DD BOV is known to leak. We have had issues with their BOV for over 5 years and refuse to run it. HKS SSQV is the cheapest, highest quality BOV on the market.
Regards,
Robert
940-683-8282 x20
Robert Del Angel
CLICK HERE FOR OUR FACEBOOK PAGE!!!
FOLLOW US ON TWITTER!!!
Master Distributor for : RPS, Tein, Seibon, Haltech, HKS, Greddy, Cusco, Blitz, Koyo, AEM, Map ECU, Eibach, Tokiko, Power Enterprise, Work, Volk, Fidanza, Defi, ....and so many more!!!
Chops@MVP is offline   Reply With Quote
Old 11-25-2009, 03:46 PM   #12
slider2828
slider2828's Avatar
^^ I agree HKS SSQV is a solid performer and never once had a problem.
Turn and Burn!
Old 11-26-2009, 11:02 AM   #13
TriniTT
is this normal?
I just discovered the problem I'm having. I took apart the bov to clean it and try to figure out why it only blows off at high rpms. I discovered my spring is red, which Blitz designates as their hard spring, intended for high boost apps (18+psi). I ordered a regular spring so we'll see if that helps once it arrives.
I know it's possible to buy these bovs with the hard spring already installed, so I wonder how many are out there that people purchased used that have the hard spring unbeknownst to the buyer.
Old 11-27-2009, 12:09 PM   #14
slider2828
slider2828's Avatar
My Buddy got his in a kit, I think that one is the normal spring. Surging at low boost really doesn't do anything to the turbo.... BUt the thing is, this POS leaks. Can't have that.....
Turn and Burn!
Old 11-27-2009, 01:15 PM   #15
TurboStrong
thanks slider28282 you have been very helpful!!!!!!
+1 for you!
Old 11-27-2009, 01:36 PM   #16
matalic SR
matalic SR's Avatar
matalic SR is an unknown quantity at this point
i use a TurboSX RFL and i have no problem with it under low boost or high boost. and i had a greddy RS and it also was fine. the price for either is not that bad
matalic SR is offline   Reply With Quote
Old 11-27-2009, 03:33 PM   #17
TurboStrong
does anyone know is the type-rs bov fits on a blitz flange?
Old 11-27-2009, 05:15 PM   #18
slider2828
slider2828's Avatar
Greddy and Blitz is going to be different.... sorry
Turn and Burn!
