Sr headgasket Q's
Im about to pull my head right now and I wanted to get a thicker headgasket. Ive been told to go with a 1.5 but what are the pros/cons of a 1.5 and a 1.1 or does it not matter at all? Q #2: Is there any major benifit from ARP head studs for higher boost?
I was wondering the same thing. I don't plan on boosting past 1.2 but I do have a 1.2 mm headgasket. Someone told me that I'll have to shave the head if I get a thicker headgasket for compression. Is that true?
If you get your head machine you need a thicker head gasket to compensate for the loss of metal. Just my guess.
Unless you have a reason to lower your compression there is no reason to get a thicker headgasket. Especially if your running stock bottom end I would not lower the compression, stock pistons are 8.3:1, if anything I'd go with a smaller headgasket to raise compression. If you have the head shaved and it's still within spec there is still no reason for a thicker headgasket. If your head is shaved enough that you need to compensate with a thicker headgasket then it's time for a new head.
Def get some ARP studs or at the very minimium some new stock head bolts. Don't reuse your stock bolts, they stretch. It's a good idea to get the head shaved when you replace the head gasket with a metal one to ensure a perfectly flat mating surface so that you get a good seal. You should be fine with the 1.1mm.
Follow the FSM. Acronym for Factory Service manual. If you don't have one, the .pdf file is free for downloading online. Answers most your DIY questions you'll have.
I put the head on first. |
I would do the head studs and on the s14 sr motor the headgaskets f up on higher boost, but sence your pulling the head might as well doit i would suggest the apexi...
![]() Join Date: Dec 2006
Stock Compression Ratio is 8.5:1, just wanna clear that up
Running a thicker head gasket is not a bad thing, it lowers the chances of detionation at high boost compared to a Higher compression boosted engine, But really its all in the tune, if you can get a good tune your safe. Im running a 1.5 mil PE head gasket boosting 21psi with no issues.
#15 |
put the head on first then the arp studs
make sure to put a light layer of silicone over the oil pump area where the head gasket seats on 1.1mm headgasket should be fine for ur appication
infinitwheels.com pitgarage.net |
