Old 11-30-2009, 12:56 PM   #1
Master Chief
Master Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to all
How to choose Valve Springs for my Solid Head.
Hi guys.
I am building my SR20DET head, with Tomei solid lifters and 270 deg cams, and i am not sure how to choose the springs to fit.
I am planing to go with SuperTech double valve springs, as i heard good things about them, and they are well priced, over the TOMEI Type B anyway.
I dont plan to go over 8500RPM probably.
I dont want to loose anymore rockers, so i am concerned with the spring stiffness, and iam not sure how to choose , as supertech have a few options.
I am sure that TOMEI have taken breaking rockers under consideration desining there springs, so i'd like to compare the Supertech with them.
SuperTech state seat pressure at 40.5mm - as 116lbs or 106lbs or 95lbs.
Not sure what that means, and how to compare this to the TOMEI springs.
On the Supertech site, under inventory you can find there springs data:
http://www.supertechperformance.com/
Here you can see the only data i found on the Tomei springs:
http://www.tomei-p.co.jp/_2003web-ca...lvespring.html
Can anyone help or recomand on the subject ?
Also if you are using any of these, can you comment on reliability issues with the head setup.
Thanks,
Dany.
Master Chief is offline   Reply With Quote
Old 11-30-2009, 01:15 PM   #2
slider2828
slider2828's Avatar
Brian Crower.... valve springs and retainers.... Do a search, but its close to what HKS specs are....
Turn and Burn!
Old 11-30-2009, 04:36 PM   #3
Master Chief
Thank you, but i dont want BC - i want Super Tech, so thats what i am asking about...
Old 12-01-2009, 10:34 AM   #4
Master Chief
No one here is runing double valve springs and can help on the subject ?
Old 12-01-2009, 10:46 AM   #5
abunai the drifter
abunai the drifter's Avatar
abunai the drifter is making his/her stupidity well-knownabunai the drifter is making his/her stupidity well-knownabunai the drifter is making his/her stupidity well-knownabunai the drifter is making his/her stupidity well-known
Send a message via Yahoo to abunai the drifter
Originally Posted by Master Chief View Post
Hi guys.
Thanks,
Dany.
it works like valve spring seat pressuer is how much presseur the spring has when the valve is closed so if your runnig higher boost id run the stornger spring but the brian crower springs are good lot of pros run them and as far as rockers braking thats a new one one me the stock ones seam to be stong
screw you guys im going drifting
abunai the drifter is offline   Reply With Quote
