![]() New S14 SR20det swap. Everything seems fine. No idling issues. TPS set accordingly.
Only issue is the car will stall if i clutch in or i'm in neutral after a little boost. My throttle body was leaking coolant, so I bypassed it. Will this cause the stalling? Also, tested the BOV (not recirc) by plugging the vacuum line and driving it. It still stalls. Any advice is greatly appreciated! Thanks! |
After searching and reading a lot of different threads, I think it is a vacuum leak. Can someone please confirm?
Vacuum Configuration: Currently I have all the vacuum lines running to the TB. 1. BOV to TB 2. FPR TB 3. Coldpipe to TB 4. Wastegate to TB <<<<---- Is this the problem? Will putting a nipple in the hotpipe and having the vacuum line going to the hotpipe solve things? |
did you ever figure out your problem? mines sorta similiar and i dont even have a bov currently so its not that for me. and any chance you could pm me how your vacuum lines are set up if you got it right?
