#1 | |
![]() Join Date: Mar 2006
In case you can't read, I was agreeing with you about stock FPR not being able to keep up (even tho time and time again people have shown it works just fine for very high boost applications. I am not wrong. You suggested that FP under 7 psi boost is 43 psi which is wrong. Sorry, but good try.
Daily driven |
#2 | |
![]() Join Date: Aug 2005
Trader Rating: (60)
![]() Feedback Score: 60 reviews
With vacuum ATTACHED (I am not talking about setting fuel pressure since it should already be set) at idle if you are running stock fuel pressure you should be at 36 psi. Since our regulators are 1:1 ratio, for every lb of boost you should see an increase of 1 psi of fp. So 36 + 7 = 43 psi. And I guess you are not understanding my logic.....you should keep an eye on the fp gauge to make sure it keeping steady fp throughout the rpm. When you are running on the dyno, the vacuum will be attached which means your numbers don't apply. So WHEN RUNNING THE CAR at stock fp, the gauge should read 36 psi and at full boost of 7psi it should be holding 43 psi to redline. And I never mentioned anything about you disagreeing on the topic of upgrading fpr in my second post. |
#3 | |
WRONG! THe car reads 36 psi FP because the vacuum is -7 psi. So when you boost 7 psi, that is actuall 36 + 7 psi = 43 psi when the manifold is at 0 PSI (atmostpheric) ......PLUS an additional 7 psi on top of that for the boost! So it should be 50 psi. Someone please chime in so it's not just me on this.
Daily driven |
#4 | |
Trader Rating: (60)
#5 | |
![]() Join Date: Dec 2004
Trader Rating: (58)
When your car is running, and the vacuum line is disconnected (simulated WOT, but without boost) it should read 43.5 psi. Knowing what the fuel pressure is, when idleing, should be somewhere in the 34-38 range...but this measurement is silly as it can be so different. Again, the main measurement should be vacuum line off, car idleing, 43.5. So at 10 psi of boost you should see 53.5, 20 psi of boost 63.5.
