Old 12-13-2009, 03:51 PM   #1
sidedrifts13
sidedrifts13's Avatar
Trader Rating: (29)
Feedback Score: 29 reviews
KA Rpm's go down slow on my 240sx twin cam ka?
I have a 91 240sx with a stock twin cam, the problem is that when i rev the motor the rpm's come down slow what can be the problem? also idles high but not all the time almost at 2 rpm then comes down to its normal idle but most of the time it iddles high? thanks for your help.
sidedrifts13 is offline
Old 12-13-2009, 04:43 PM   #2
jorge1190
jorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to alljorge1190 is a name known to all
Im pretty sure that this is due to the KA having a really heavy flywheel. My KA does it too
jorge1190 is offline
Old 12-13-2009, 05:39 PM   #3
sidedrifts13
Trader Rating: (29)
It does it on and off comes and goes but idle is high ima check the timing and the tps to see whats up also sometimes not all the time car dies when coming to a stop anybody have an idea what can it be? could it be bad ground?
Old 12-13-2009, 05:43 PM   #4
payne219
payne219's Avatar
payne219 is an unknown quantity at this point
Vacuum leak most likely If your car is falling out at stops and has high idle. Check your hoses in and around the intake manifold brake booster ect... see if you can find a leak. that might help
payne219 is offline
Old 12-13-2009, 05:54 PM   #5
sidedrifts13
Trader Rating: (29)
for sure ill definately check the vacumm lines thanks
Old 12-13-2009, 10:43 PM   #6
evmal613
evmal613's Avatar
evmal613 is an unknown quantity at this point
i say vacumm. I had the same issue with my car
evmal613 is offline
Old 02-02-2010, 09:44 PM   #7
D-CYPHERED
D-CYPHERED is an unknown quantity at this point
damn you didnt tell me all this about the car
D-CYPHERED is offline
