Old 12-13-2009, 11:01 PM   #1
perzbenz
perzbenz is an unknown quantity at this point
1992 Mercedes Benz 500SEL VIP Full Fabulous SEMA Car
I'm starting a 190E Project. So I need to sell 'the tank'. The pictures of the car show the car higher than it actually is now. The car is currently as low as it is in the front. My email is [email protected] if you don't want to PM. Im located in Orange County. Asking 6,000 Firm.
Car went to SEMA in 2002 for Fabulous
Heres for some information about the car. Full stack of receipts available.
127k Miles
Clean title, no accidents, super clean carfax, autocheck, does not leak oil and NEVER failed smog.
Brilliant Silver Exterior with Gray Interior
Fabulous Kit
Fabulous Profounds 20x9 and 20x10.5 (PERFECT CONDITION, Rechromed less than 2 months ago. Paid $1160 for the rechrome)
Pilot Sport II Tires, almost brand new, still with nipple things showing.
Fabulous Exhaust
Fabulous Foglights
Eibach Springs
KMAC Adjustable Rear Camber Bushings
I have lots and lots of receipts for maintenance work done. Heres a list of some of the things. Most done recently.
Timing Chain Job Done (Big thing)
Replaced Wiring Harness (Big thing)
Replaced Ignition Switch Electrical
Replaced Ignition Tumbler Cover
Replaced Ignition Steering Lock
Replaced Power Steering Reservoir
Replaced Blower Motor
Replaced Blower Regulator
Replaced A/C Filter
Replaced Closing Pumps (for autoclosing doors and trunk)
Replaced Window Motors
Replaced Window Regulators
Replaced Wiper Regulator
Replaced Temperature Sensor
Replaced Water Valve
Replaced Water Sensor
Replaced wiper contacts
Replaced Fan Clutch
Replaced Radiator<br>
Replaced Aircells/hydraulic fluid/transmission fluid.
Replaced O2 Sensor
Replaced swaybar link
The rear can be lowered basically dumped touching the floor by adjusting the hydraulic suspension rods and changing spring pads. The rear can also be cambered out by adjusting the adjustable camber bushings
Mechanical Condition: Pulls nice. 120 feels like 65 as it should. Interior is extremely quiet when cruising at any speed. There is a bushing on the front left part of the suspension that would need to be replaced sometime, so the front left does squeak at times. Other than that there isn't any problems with the running condition of the car. The car does not run hot, which is a big thing with these older benz's if unmaintained.
Interior Condition: Drivers seat has wear on the left bolster. All interior buttons are in working order. Factory stock Bose speaker system. Factory amplifier for the speakers needs to be replaced or rebuilt.
Exterior Condition: Paint is nice and shiny. The car does rub on dips on the rear fenders lips because its not rolled enough. Front bumper does have scrape marks on the bottom, and an inch crack. There are two spots on the right side bottom side panels that are an inch long, kinda look like keymarks. Right side rear sideskirt has an amazingly amazing crack on it. The front fenders have a dimple on the tops from being too low and turning. Car does have some doordings.
perzbenz is offline   Reply With Quote
Old 12-13-2009, 11:49 PM   #2
Slammed180
Slammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of light
Those are 20's? Damn that car dwarfs those wheels, lol.
Clean car, and a sweet price too. GLWS.
Blow me, bitches.
Slammed180 is offline   Reply With Quote
Old 12-15-2009, 01:24 PM   #3
Xclusive_racer
Xclusive_racer's Avatar
Xclusive_racer is an unknown quantity at this point
clean vip benz....just like my body kit
You Build Cheap! Your Car Will Feel and Drive Cheap!
Xclusive_racer is offline   Reply With Quote
Old 12-19-2009, 05:16 PM   #4
perzbenz
Heres some new pictures of the car
Old 01-01-2014, 07:06 PM   #5
izzy-
izzy-'s Avatar
izzy- is an unknown quantity at this point
izzy- is offline   Reply With Quote
