Old 01-04-2010, 04:21 PM   #1021
Om1kron
Om1kron's Avatar
Simone Video Blog - Boost Gauge Readings on Vimeo
hooked up a boost gauge for some readings, that's what I got right there.
also put in the older coil pack, car still runs the same. The only difference is the model number on the newer coil pack is 01 at the end of the serial number instead of 0 like the other 4 I have.
The model number is exactly the same on them, so I really doubt that matters at all.
Tightened down the alternator tensioner today, hopefully it doesn't come loose again. I will need to find a nut or something to thread on the other side of the adjustment bolt to keep it in place since it's vibrating loose.
Wayne Edwards
https://om1kron.blogspot.com
Old 01-04-2010, 04:38 PM   #1022
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Originally Posted by Om1kron View Post
Oh don't worry man, if it were up to me financially id have a tomei crate engine in it and some crazy ass turbo set up. But baby steps, I'm sort of glad that I'm having these problems because I learn more about the set up and can help other people with their problems.
Troubleshooting is seriously the best way to gain automotive knowledge...the more you start checking stuff the more it all really makes sense.
In regard to your vacuum gauge showing -20, that's perfect. YOu're pulling that much vacuum, which is right on the money for your engine. Zero indicated the point where you begin to go out of vacuum, and into boost. If your vacuum was pulling persay, around 10...then you'd have a cam/mechanical timing issue, but that's not the case.
However I can't believe how much boost it's making just by free revving the engine...either it's been so long since I've paid attention to that aspect, or any car i've ever tinkered with hasn't done that. Hell with my baby launch control the car makes 4-5 psi...and you're making 7 just free reving! Either that's common and I never realized it, or something else is wacky.
Old 01-04-2010, 04:56 PM   #1023
Om1kron
Om1kron's Avatar
my car maybe has a special t25 or all of the oil sitting in it is helping it spin faster haha j/k. I'm trying to put on my wheel spacers now, I for some reason thought it was easy to take off the rear brake disc, apparently I was mistaken and it's rusted on there.
Wayne Edwards
Old 01-04-2010, 05:55 PM   #1024
Om1kron
Om1kron's Avatar
waiting on FRSport to see if I can exchange these items... from what it looks like I ordered the ones for the front hubs instead of the rears.
http://om1kron.blogspot.com/2010/01/...lspacecom.html
cause these aren't going to fit in my hubs. And now my car is in pieces.
FUCK!
Wayne Edwards
Old 01-04-2010, 06:34 PM   #1025
KoukiMonsta
KoukiMonsta's Avatar
KoukiMonsta is a well-known jackass
yeah thats right, 20 is great for vac.
but im also with u Cody as i dont think my motor will make boost just reving. it needs a load to spool. but im not running a t25. mayb a smaller turbo will spool w/ no load? someone please chime in
@UpshiftEngineering
KoukiMonsta is offline   Reply With Quote
Old 01-04-2010, 06:50 PM   #1026
codyace
codyace's Avatar
Trader Rating: (58)
Simone : My 1996 240sx: www.wheelspace.com
FUCK!
Ah yes, Knurl size on S14's are different front to rear. I ended up buying ARP front studs (from a Mustang iirc) and Moroso rear studs (from a camaro iirc). A quick search should show you which ones to use...I'll check my jegs receipts later to see for sure...goin out here in a sec.
Old 01-05-2010, 10:06 AM   #1027
OBEEWON
OBEEWON's Avatar
Hmmm, sounds like a super lean mix?? That would explain the missing up top? Not sure. Do you have a wideband? I cant see the vid at work.
When my car was blowing out spark I was making like 5psi free revving as well. That much boost without load is not normal.
Old 01-05-2010, 07:45 PM   #1028
codyace
codyace's Avatar
Trader Rating: (58)
It's plausible...gotta think, if the unburnt fuel is exploding in the manifold, it will create boost (like a two step by msitake)...but he said he's been able to free rev and drive to redline...daaaarn
We need to get a "K"alifornia Zilvia guy down there to get a consult on the car sapsap!
Old 01-05-2010, 07:53 PM   #1029
Om1kron
Om1kron's Avatar
yeah once i get some engine management i'll have steve shadows tune it.
Wayne Edwards
Old 01-05-2010, 11:33 PM   #1030
Om1kron
Om1kron's Avatar
ugh, looks like i'm going to have to drive down to frsport tomorrow to resolve this wheel spacer shit.
I thought it was going to be a wham bam thank you man thing but obviously the person handling their email inquiries is not the person handling their aim account. I also ordered some hawk hps pads for my rear brakes, I didn't realize that screeching noise was the rear brakes.
Thought it was my fronts since bbk's screech when cold.
Wayne Edwards
Old 01-07-2010, 03:13 AM   #1031
Om1kron
Om1kron's Avatar
What a glorious day, so after an aim conversation and confusion in email, I decide to drive down to frsport today to handle my item echange... lets just say I will stick to having items shipped from them to me. It cost probably 20 dollars in gas alone round trip in traffic just to get to them, not to mention the 2 hours of traffic I hit on the way back home.
On the way I stopped and dropped off my rotors for a resurface since I got new pads on the way... from frsport.
figure I'll knock everything out at once.
So far the threading the knurls or shanks into the hubs is a bitch. I thought I would be smart and put the brake hub back on and double up on the spacers, but my lug nuts are tapered so they just burrowed into the spacer.
I gave up on that for now after getting 5 in 80 percent of the way and will figure out how to finalize it tomorrow. otherwise they're just going to be in 80 percent of the way, I don't want to snap any of them by trying to pull them into their seat since they should've been pressed in, in the first place.
Then my roommate tells me someone wants to buy the oj bronco, hella bros show up with a fucking monster truck with a turbo that sounded like it raped babies for a living.
after pushing the bronco out in the street, some words were exchanged, and I think my roommate didn't want to get rid of the non running car afterall. and we pushed it back into my driveway.
FML...
anyway, think my rear pads needed replacing? I think I could've put about 10k more on those pads, they don't even do any work anyway. The screeching just got annoying.
stock on the left, hawk hps on the right.
Also I figured this would be a good idea, VHT high temp caliper paint to paint those ugly ass rusty rotor hats, and also painted the spacers. I didn't need red wheels, silver spacers, and rusty hub as my rear wheel outlook. Fuck painting the calipers, this is good enough for me.
enjoy the little things.
Wayne Edwards
Old 01-07-2010, 06:22 PM   #1032
Om1kron
Om1kron's Avatar
10mm spacers verdict is in...
Simone : My 1996 240sx: 10mm spacers verdict.
click on the blog link for more pictures...
I would post pictures of the volk lugnuts I destroyed to seat my wheel studs, but I don't want to make you guys at home cry too.
Wayne Edwards
Old 01-07-2010, 07:16 PM   #1033
NemeGuero
No more nissan.
NemeGuero's Avatar
lookin fuckin rad dood.
but..
why aren't you driving the shit out of this car yet?
Old 01-07-2010, 07:19 PM   #1034
KoukiMonsta
SECKSeeeeeeee
@UpshiftEngineering
Old 01-07-2010, 07:33 PM   #1035
Om1kron
Om1kron's Avatar
read back a few pages nemo... it needs a tune, and my tps sensor is currently ziptied to the throttlebody.
Wayne Edwards
Old 01-07-2010, 08:34 PM   #1036
homeslicej2
homeslicej2's Avatar
homeslicej2 is making a name for him/her selfhomeslicej2 is making a name for him/her self
OP, Cody, & Kouki. My Redtop runs -20 vacuum at idle, -23-25 while cruising under no load, and my turbo (stock T25) will not build boost free-revving under no load. I tried it when I swapped out the stock turbo elbow for a Megan one. I wanted to hear what the SR sounded like open DP.
homeslicej2 is offline   Reply With Quote
Old 01-07-2010, 08:48 PM   #1037
Om1kron
Om1kron's Avatar
then I obviously have a fuel problem... I want to have the injectors rebalanced at RC when I get a chance and also have them run through a diagnostic to make sure they're not leaking.
Wayne Edwards
Old 01-07-2010, 08:50 PM   #1038
240XTC
Location: 1st amendment. Not my fault you dont like me. Does not give you the right to abuse your mod and continue your harassment in slander towards my profiles. Cowards.
240XTC has a brilliant future240XTC has a brilliant future240XTC has a brilliant future240XTC has a brilliant future240XTC has a brilliant future240XTC has a brilliant future240XTC has a brilliant future240XTC has a brilliant future240XTC has a brilliant future240XTC has a brilliant future240XTC has a brilliant future
this sheets cleeean...
240XTC is offline   Reply With Quote
Old 01-07-2010, 09:48 PM   #1039
Bubbles
Bubbles's Avatar
Bubbles is close to perfectionBubbles is close to perfectionBubbles is close to perfectionBubbles is close to perfectionBubbles is close to perfectionBubbles is close to perfectionBubbles is close to perfectionBubbles is close to perfectionBubbles is close to perfectionBubbles is close to perfectionBubbles is close to perfection
I need more info.
For all the world knows, my vagina could be moist with desire as we speak.
Bubbles is offline   Reply With Quote
Old 01-08-2010, 09:08 AM   #1040
KoukiMonsta
thanks, looks like im not crazy. and as far ass open DP Sr.....hells ya
im with you here on the fuel problem. do u have a FPR or pres guage?(srry i forget even tho i have read ur whole build lol)
@UpshiftEngineering
Old 01-08-2010, 11:11 AM   #1041
Om1kron
Om1kron's Avatar
haha I definitely love the way they sound, open dp. But so do the police.
http://www.vimeo.com/4672699
but i guess i've had a fuel problem for quite some time, it happened after I stored the car it started running like this.
im with you here on the fuel problem. do u have a FPR or pres guage?(srry i forget even tho i have read ur whole build lol)[/quote]
No, no gauges. when I was working I was going to buy a racepak meter and various sensors instead of having my car full of 1000 dollars worth of little circular pods.
http://www.youtube.com/watch?v=eAur-3i-zbw
Wayne Edwards
Old 01-08-2010, 11:35 AM   #1042
codyace
codyace's Avatar
Trader Rating: (58)
See, that's normal to me....having a car build boost like Wayne's is rediculous just free reving...but it's been so long since I've played with a t25 car that I forgot haha.
Police really like open exhausts, one of their favorite sounds haha.
LOL
Old 01-08-2010, 05:40 PM   #1043
homeslicej2
Np and yeah, it was quite an invigorating sound. Made me
Rub it in Cody, just rub it in LOL.
Old 01-08-2010, 11:25 PM   #1044
Om1kron
Om1kron's Avatar
steve shadows is going to take a look at it tomorrow.
Wayne Edwards
Old 01-08-2010, 11:47 PM   #1045
97240TB
97240TB's Avatar
97240TB is an unknown quantity at this point
http://www.youtube.com/watch?v=eAur-3i-zbw[/quote]
I'm hoping you do the racepak cause I was planning on going the same route, I'd like to see how easy the install is.
97' 240SX, VQHR swap Combplete.
97240TB is offline   Reply With Quote
Old 01-09-2010, 11:40 AM   #1046
kalypso123
(ノಠ益ಠ)ノ彡
edit::
the pull turned out nice.
Old 01-09-2010, 12:23 PM   #1047
KoukiMonsta
fuck u west coaster j/k
let us know, should diagnose "possible" fuel issue
Originally Posted by kalypso123 View Post
you smoothed the lumps on the fender really nice.
ya man!! i cant get over how fucking sexy this car is. i wish i could see it for realzzzzzzzz
@UpshiftEngineering
Old 01-09-2010, 01:33 PM   #1048
lflkajfj12123
kinda curious to find out what the issue is
post up om1kron
Old 01-09-2010, 02:37 PM   #1049
s13pignose
s13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of light
^^^^ yeah good luck with the diagnosis
s13pignose is offline   Reply With Quote
Old 01-10-2010, 01:40 AM   #1050
Om1kron
Om1kron's Avatar
Simone : My 1996 240sx: @ Shadow works.
http://www.youtube.com/watch?v=49p3v-8wQHU
my timing was off by 33 degree's, once corrected the car was barely drivable on the way home. I'm depressed a bit since I'm moving and I don't really have any money at all to fix this car.
Fuck you economy.
Wayne Edwards
