08-14-2009, 12:47 PM | #61 | |
205.55.15 on the front 225.50.15 on the rear on a 15x7. i don't think with another 10+ psi of boost a 225 drag radial is gonna hook.
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo |
08-14-2009, 01:36 PM | #62 |
Bandwagon.
when you did your 2jz swap did
you have to push back the firewall or anything like that or it was just a simple drop in but with custom brackets and mounts to hold the engine up |
08-14-2009, 04:20 PM | #65 | |||
Thanks everyone.
08-14-2009, 04:32 PM | #66 |
Awesome build. Dont worry about people saying it isnt much faster than other 400whp ka/sr's. 9/10 of them that you run into are running t25/t28's or t3t4's at 10psi. Also nothing sounds like an I6 in comparison to any 4 cylinder no matter how built they are.
08-14-2009, 05:39 PM | #67 | |
400whp KA/SR on stock bottom end is a ticking time bomb, and this car should do 370ish at the wheels mostly stock.
08-20-2009, 01:59 PM | #69 |
got an appointment next friday (28th) for the cam swap and to wire up the last things for the electronics.
And then they will put the car on a dyno and give it a tune. stay tuned
08-20-2009, 04:21 PM | #71 |
Bandwagon.
ok toretto......
08-24-2009, 10:35 PM | #75 |
u finaly got it finished !!! awesome last time i talked to u u said it wasent going to be done for a while ... congratz man !!! im still having that stupid wiring bug with mine ! , i just want it to run 100% *CRY* !!!
93 2jz-gte S13 fastback and 93 ca18det S13 coup |
08-24-2009, 10:39 PM | #76 | |
some things have gone wrong on the car, the fan's decided to take a shit, so this friday i'm getting some ILL GARAGE fan's for it. and uhm it's getting a few more things taken care of. Thanks again man!
08-24-2009, 10:51 PM | #77 |
i call tech 2 all the time, i just dont have any doh right now my only option and i think my best bet would be just 2 send them the whole harness and have them go over it. sean's good ! Doctor tweak is the one who originaly did my harness and they fired him because random shit like whats hapening to me, would happen to peoples cars, the 2jz is a god among engines but its weak link is that if one little sensor or wiring thing isant right it wont run 100% to protect itself,( witch is a pain but a good thing i guess ) but other than that the only other thing i can think of is just not to go cheap on a clutch .... wich leads me to my next question ...... i know its an auto... but make sure u have it serviced even the auto's can develop crank walk because of the tanny ....
09-29-2009, 11:13 AM | #80 |
thanks alot man!
Yes it does We have had the car at A-spec tuning for the last month or so now. they did a cam swap (stock jdm cams to stock usdm cams) Wired up a AFC NEO, NGK Wideband,Greddy Profec B,Turbo timer,and ended up swapping out my hks ssqv for a Tial bov (HKS is for sale for $120 shipped ) the car went on the dyno with the the old HKS ssqv, but the intercooler piping kept blowing off, and the c-clip on the bov kept making the bov come off the car at about 4500rpm, so we couldn't get a full pass or even a complete tune put on the car. here is the dyno vid - YouTube - 2JZ 240sx dyno run. (only a small pull to 4500rpm) any geuss's at what power it made? 10psi untuned running rich car only running to 4500rpm.
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo Last edited by Flicktitty; 01-07-2010 at 05:35 PM.. |
01-07-2010, 05:34 PM | #81 |
How about a little more updated news?
we swapped out the HKS SSQV bov in favor for a Tial bov. and did some more engine bay cleaning/ detailing. picked up some truck peices (trunk was stripped when we got it) we put some miles on the car. (this is as low as the car can go do to some suspension peices rubbing, but that will be delt with over winter, needs more low lol.) i took these pic's about over month ago, the last night the car was out for the year. i got the women some Pink RJS racing harness' for the car for christmas and installed them a few days later (no pic yet) picked up a new Tial 38mm wastegate this is what i have been working on this week, there coming along pretty well, still need alot more time and energy still have ALOT more to order. We decided instead of getting a "cheap" single turbo kit, we are just going to peice together a kit. consisting of these parts Tial 38mm wastegate. Treadstone cast manifold Precision BILLET 6265 .68 a/r Anti-surge cover polished and coated Boost Logic T4 turbo blanket Dei black ehaust wrap. then i still need alot of other crap. stock twin removal starting soon. :bigthumb
01-07-2010, 10:49 PM | #86 |
yeah it willl be lower in spring.
the front tension rod rubs the sway bar. it only rubs cause the sway bar is a larger aftermarket one, and cause there is a spacer so the sway bar doesn't rub on the oil pan.
01-07-2010, 11:01 PM | #88 |
yeah i would bet it's a solid 2"? spacer. i'm gonna maybe shave the spacer a little since there is a good amount of clearance, and once the stock sway bar goes on, down we go. way to much wheel gap up front.
