12-05-2009, 04:38 PM | #1 |
Parts Shop MAX ~Multi Link and Chassis Parts~ Real time quotes & orders in thread!
PURCHASES AND SHIPPING QUOTES DIRECTLY FROM THIS THREAD!
SIMPLY CLICK THE BLUE ADD TO CART LINK VIEW CART Our third generation arms and rods are stronger than ever. MAX multilink features more clearance for lowered cars than any other brand, as well as the adjustability you need to dial in your cars maximum performance. They let you set your personal preferences on characteristics like turn in, grip, tire wear and drift initiation. All of the MAX multilink parts are equipped with premium Japanese pillowball joints that eliminate OEM rubber bushings for a precision, predictable, tactile driving experience. The quality is on par with the best the world has to offer and the unique design features make them an unbeatable value. The MAX multilink can be complimented by using or famous MAX coilovers, Subframe Collars or Subframe Solid Risers, Super Steering Angle Knuckles, and IF tie rods for a perfectly tuned suspension setup. RUCA $200+sh CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE In stock date is 5-9 TOE ROD $200+sh CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE In stock date is 5-9 TRACTION ROD $180+sh CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE In stock date is 5-9 TENSION ROD $200+sh CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE In stock date is 5-9 SUBFRAME COLLARS $50+sh CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE In stock date is 4-26 SUBFRAME SOLID RISERS $100+sh CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE In stock date is 4-26 MAX R.U.C.A. (Rear Upper Control Arm) for camber adjustment on Super low S chassis cars ~100% TIG welded ~3mm/.120 wall thick DOM tube ~Single consistant bend keeps stress evenly distributed ~NMB Japan spherical bearings with dust covers ~50mm 1 piece forged rod end ~Powdercoat orange paint and Gold chrome finish on adjuster and rod end ~Angle union between adjuster tube and arm helps clear the chassis on lowered cars ~Upswept arm helps clear Axle boot on lowered cars ~Arm length maintains around -1 degree of camber on lowered cars with minimum adjuster thread exposure ~Compatible with any coilover brand except Tein on s13 *If your car currently has no adjustable multilink you must install RUCA and TOE together to adjust your rear alignment properly because in the S chassis when you change the camber it effects the toe setting. RUCA $200+sh CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE In stock date is 5-9 MAX Toe Rod ~Double TIG welded fork bracket ~31mm 6061 CNC amuminum adjuster tube is located far away from the subframe bracket for ease of adjustment ~23mm solid steel bend clears the subframe on extremely low cars ~NMB Japan spherical bearings ~40mm TIG welded rod end ~Orange and gold aluminum hard anodizing and Gold chrome steel finish *If your car currently has no adjustable multilink you must install RUCA and TOE together to adjust your rear alignment properly because in the S chassis when you change the camber it effects the toe setting. TOE ROD $200+sh CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE In stock date is 5-9 MAX Traction Rod ~Double TIG welded fork bracket ~31mm 6061 CNC amuminum adjuster tube ~23mm solid steel bend clears the subframe on extremely low cars ~NMB Japan spherical bearings ~40mm TIG welded rod end for S13 ~44mm 1 piece billet aluminum rod end for S14 ~Orange and gold aluminum hard anodizing and Gold chrome steel finish ~Increase traction by shortening this rod 1cm from stock length on higher cars or lengthen this rod for super low cars for correct geometry. *OK to install independant from any other suspension part. *27mm short and skinny wrench is recomended for ease of installation in cramped rod end/subframe area. We sell a custom wrench for $5. TRACTION ROD $180+sh CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE In stock date is 5-9 MAX Tension rod ~These come with the same 1pc. forged steel end joint like our third generation RUCA. ~They have the yellow silicone dust covers and the new steel ball joint spacers as well. ~Steel locking nuts for the length adjustment are in place of aluminum from the previous model ~The anodized 6061 aluminum tube and end bracket are carried over to the new model. ~Hardware for the LCA is included. *OK to install independant from any other suspension part. *More caster creates a self steer feeling while drifing and less caster is good for cars equipped with our super angle steering knuckles. TENSION ROD $200+sh CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE In stock date is 5-9 MAX Subframe Collars ~CNC 6061 Aluminum ~Stiffens OEM bushing to eliminate wheel hop after clutch kick ~C shaped upper collars for easy installation ~Gold hard annodized finish *Can be installed independant of any other parts SUBFRAME COLLARS $50+sh CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE In stock date is 4-26 MAX Subframe Solid Riser ~Completely replaces OEM Subframe Bushing ~Raises Subframe a half inch for lowered suspension geometry correction ~Makes more clearance to raise exhaust ~Slip fit, epoxy-it-in installation (no press needed) ~CNC 6061 Aluminum ~Gold hard annodized finish *Made specifically for low ride height vehicles to help fix roll center problem. *Please see our products forum for OEM bushing removal instructions *You must bend the E-brake cable bracket to reroute cable so it does not rub the driveshaft. SUBFRAME SOLID RISERS $100+sh CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE In stock date is 4-26 Some history and the making of these parts: Here is a video of the arm that we make in the usa, slightly outdated now that we TIG weld this part ~ but still interesting. Adjuster, lock nut and pillowball spacer shown before finishing to reveal all steel components. After plating and dust cover installed: Installations Drift heaven Magazine. April 2009 ,Pg32~39 "simple parts but super important" "They all look similar but unique in their own way" Drifters change their nissan multilink arms for different reasons. "I don't like the stock rubber bushings", "I wanna be-able to do a proper alignment", "when I dropped my car, the stock arms didn't have enough adjustability", "I wanted it to look good". So which brand are you going to choose? These parts only consist of a shaft and a joint but each companies have their own theories about how they should be and what kind of material it should be. "Max believes in making parts for super low drift cars. They have a sister shop in USA and their friends and customers only desire to drift in super low drift cars. So their RUCAS and toe arms have special bend and angles to clear from the frame, subframe, knuckle, and axle boots. They also chose thick aluminum body to keep the weight down inside the wheels while maintaing its strength." VIEW CART
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! Last edited by DC Dan MAX USA; 04-23-2010 at 03:25 PM.. |
12-05-2009, 11:14 PM | #2 | |
Trader Rating: (25)
Feedback Score: 25 reviews
Everyone, buy this shit.
So good. My buddy and I took his car (has FULL PBM suspension catalog) down to a small garage for an alignment and the guy who aligned it said they were the best aftermarket arms he's ever used.
12-08-2009, 07:34 PM | #4 |
Dan got the rucas and toe arms today. They look awsome ,let see how they perform on a drag car
I will be getting the traction rods and subframe collars soon...Thanks...Omar
618 whp tuned by alpha |
12-10-2009, 07:21 PM | #5 |
thanks guys = )
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! |
12-11-2009, 01:11 AM | #6 |
YEAH!!!!!! i very much enjoyed this new feature. ordered tension rods and some vinyl. wish i could have ordered both the small and large stickers tho. guess i gotta buy something else now.
12-11-2009, 01:59 PM | #7 |
this is the cutting edge forum technology - I try to improve things, never perfect but always getting closer - thanks for your business
12-23-2009, 06:24 PM | #9 |
yes with exception of the ball joint spacers, but it comes with both types.
12-23-2009, 08:20 PM | #10 |
I want to buy your RUCA but have Tein Flex on my S13. Whats the reason behind it being not compatible with Tein coilovers? Is there anyway to modify it?
I'm sad =(.
Outside Family |
12-28-2009, 03:02 PM | #11 |
I had a customer complain about interference on teins. I think the issue was that the spring stack is taller and the bottom cup is lower than our coilovers which puts the spring collars in the way of our arm. Now I never saw any pictures, but when I get feedback like that I like to warn other customers about the possible incompatibility however Tein makes alot of different styles of coilovers and the arms are setup for the best scenario when you have -1* camber on a slammed car. I dont know whick model of teins the customer had and I dont know the alignment settings, so there is a chance that it could work for you depending on the design of your teins and the settings.
12-29-2009, 08:02 AM | #12 | |
I have old Tein HR. I had the springs all the way down and the lock rigs were hitting. i fixed the it raising it back up. you can run them, but you just cant have it slamed to the max... I'm saving up for Max coilovers now. I love everything they make!! |
12-29-2009, 08:54 AM | #13 |
I have a noob question. I plan on buying your guys's whole set soon, just wondering if I'm going to be able to slam my car first, then buy your set. I have no suspension mods other then....Megan...(bought the car with them already) street coils and I'm throwing on my weds 18x9.5-3 and 18x10.5-14 on stock fenders. Is anything going to stop me from getting my rims fitted and on first? Seeing as tho your company deals with low cars with these offsets daily? Thanks guys and I can't wait to buy some of your products.
97 Kouki- Third times a charm Instagram@Koukimonstrr |
12-29-2009, 09:04 PM | #14 |
Yes you can slam the car but the problem is the alignment will be shit.
You should do all the aftermarket alignment parts first you need fiberglass widebody to fit those wheels, but you cant install the fiberglass parts properly till you have the alignment done. You want a flush fit, and the fiberglass parts can bend but you need to have everything in place first so the flushness is there when you screw in the overfender. you dont want to make multiple sets of holes installing the aero parts because you dont have all the multilink
01-02-2010, 11:26 AM | #16 |
I always email tracking to the paypal address.
01-02-2010, 11:37 AM | #17 |
How much for S13 Coilovers and Super Angle Steering Knuckles, shipped to Saskatoon, Saskatchewan, Canada. S7N 3T7?
08 Mitsubishi Evo X MR 89 Nissan 240SX Last edited by Red Dragon3; 01-02-2010 at 01:14 PM.. |
01-04-2010, 06:46 PM | #18 |
$1361USD shipped for the coilovers with SAK parts only kit.
01-04-2010, 08:35 PM | #19 |
Has the S13 RUCA have been shipped out yet? I ordered awhile back and you said I will receive the RUCA's by the end of December. I do notice that they are instock Jan. 2, but u did say that I will receive them by the end of December. I still haven't gotten any notice or tracking #
01-04-2010, 09:03 PM | #20 | |
since some of them do not say in stock now, but its already past the date, does that mean that they are all in stock? I'm looking at the RUCA, Tension rod, traction rod, and rear lower toe rod for the s13.
http://silaudrey.blogspot.com/ |
01-07-2010, 12:34 PM | #21 |
the status as of today is that we have traction, toe and tension in stock now, and subframe collars are in stock now. Risers have just sold out. RUCA arrived int he USA 12-30 and we are waiting on customs clearance to send to customers
the holidays have screwed up my predictions on the arrival a little bit
01-14-2010, 06:50 PM | #23 |
$828 shipped
01-18-2010, 12:56 PM | #24 |
Do you know when you'll be getting the subfre risers back in stock? I should have ordered them back when they were in stock. lookin like a fool with my subframe on the ground.
01-18-2010, 07:29 PM | #25 |
probably a month from now
01-24-2010, 02:01 PM | #26 |
My parts come in on Tuesday!! I can't wait to install, I installed on my buddies s14 and was impressed. These arms will complete my suspension and I will post a complete list of the stuff i have and the performance of the car. Thanks guys!!!
01-24-2010, 07:35 PM | #28 |
Well let me know when they come in, I just got done putting my subframe together and this is the last peice before I bolt it back in.
Also at the same time I will be getting a HMIC, I posted in the other thread a while back, did you guys ever get around to making a turbo intake pipe to go with that? |
01-25-2010, 06:33 PM | #29 | |||
We have the parts to do the inlet now, but have not had the time, I need cars to do the mockups too.
