#8343 | |
![]() Join Date: Jul 2006
that car also belongs to VAs13 on here. i think. its also been posted in this thread quite a few times, but this car never gets old |
#8345 | ||
#8348 |
![]() Join Date: Oct 2008
Trader Rating: (131)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 131 reviews
I want to run my future setup past you guys for some advice. Here is where I left off last fall:
![]() F: 17x9 +12 225/45/17 Yokohama S-Drive (-2 camber) R: 17x9 +12 245/40/17 Yokohama S-Drive (-2 camber) Wheel specs were good, but ride height and tire sizing was off. I picked up Johnny's CR Kais and they are being repainted right now. I want to order new tires that fit better and go lower this spring with the full kouki aero. Here is what I am thinking: F: 17x9 +17 215/45/17 (or 215/40?) R: 17x9 +12 (5mm spacer) 225/45/17 Interested to see what you guys think. I know it won't be super cambered/aggressive, but I want to keep it semi-streetable with some grip out back. Power is going to be going from about 220whp to 290whp in the spring as well. I think those sizes should fit pretty well from what I have seen in this thread. |
#8349 |
#8352 | |
![]() Join Date: Nov 2005
I would recommend 215/40 in the front and 225/40. 45-series sidewall looks goofy if you're going to want to go low. You might need bigger spacers though, depending on what camber you run. You're going to need at least a 5mm spacer in the front and a 10mm in the rear to make up for the thinner tire if you're wanting to rock the same camber specs/same tire flushness. Or you could just rock a 225/40 up front and a 235/40 in the rear, which would give you a little more grip and less space to fill up with spacers. Probably what you're going to want to do is just fit the tires and wheels with no spacers, adjust to your lowness and camber specs, and then figure out which spacers to run.
#8353 |
Good info, thanks man. And yes, I realize a smaller tire will be less flush. I would be fine with running a bit less camber than the -2 degrees I was running. My rear tires got smoked in about 7k miles, but I must have gotten a bad alignment. I wouldn't expect -2 camber to eat a set of tires that fast without the toe or something being off.
#8354 |
Yeah they definitely shouldn't go away that fast. That's near stock alignment specs on some cars, the tires should last close to their rated length.
Make sure they dial in zero toe this time.
#8356 |
The Architect.
![]() Join Date: May 2006
Trader Rating: (392)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 392 reviews
215/40 fronts, 225/45 rears.
Done and done. |
#8357 | |
225/45 looks like balls imo, i'm going to be running that on a 9 just because i got a pair for $40. i'd go with a 215/45 front and rear, so at least you can rotate them if you burn the rears down too much... 225/40's on 17x8+8 ![]()
#8359 |
![]() Join Date: Jul 2005
I would personally suggest 215/45s up front and 235/40s out back because they're almost exactly the same tire height.
OR do what Ed said and run 215/45s all around...but since your rear is already set up to accept a 245/40 I would say run the 235/40. -2 shouldn't kill your tires in 7K either. I am pretty sure AP2 S2000s run -2.5 factory.
![]() Instagram - SJKnoop |
#8360 | ||
![]() Join Date: Sep 2007
Trader Rating: (25)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 25 reviews
#8362 | |
Trader Rating: (25)
Of course they're expensive, they're not common at all.
#8363 |
![]() Join Date: Dec 2006
for what you pay for them... if i found some for cheap i'd prolly grab them but... other than that i will never run them. But i'll be honest this opinion is based of driving turbo FWD cars with them... so yea... maybe its a lil biased .. idk give me some maybe ill change my opinions
im still in never ending debat my self of what to run on the front with my 17x9.5s... everyone keeps saying 215/40 or 235/40(replaces 225/45 i have on them)
#8365 | |
RULES: ![]() |
#8367 |
Admin Asshole
![]() Join Date: Mar 2002
Geezy, stop posting. If you have questions about someones car, then PM them, but stop cluttering this thread with your ignorance.
"Speak softly,..." -Pres. Teddy Roosevelt "Be polite, be professional, ..." -Gen. James Mattis |
#8369 |
![]() Join Date: Oct 2003
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
That car was in formula d/d1 from what I remember. So, id say it drifts more then just fine.
![]() Dont think ive put this pic in here before. I still miss this car. ![]()
