Old 01-30-2010, 10:52 AM   #1
JDS Performance
JDS Performance's Avatar
Trader Rating: (53)
JDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of light
Feedback Score: 53 reviews
FS: NC; 240sx Garage Sale - Cleaning Out
Kannapolis, NC 28081
[email protected] < Paypal too
KA24DE "Real" Crower Rods (not Brian Crower) - $729.99 is what they sell for new - Crower Rods for KA24DE
$600.00 for rods shipped in the US
Pistons are sold
They were pulled from a built motor - that was not speced out correctly and it spun a main bearing on break-in - everything was removed before any damage was done.
The piston tops will clean up easily as well.
I was going to use them in my turbo motor but money is tight now so they gotta go.
S14 HKS Hi Power Catback $200.00
Its banged up but still works great
S14 "mudflaps" or whatever they are called - $25.00
S13 KA24DE DOHC MAFS - $50.00 Shipped OBO
S13 KA24DE DOHC MAFS w/ top half of air tube (has the rubber seal) - $55.00 Shipped OBO
S13 KA24DE 5 Speed Speed Sensor - $65.00 Shipped OBO
FS; S14 Dash
$175.00
Shipping will be around $100-$150 depending on location
I have a S14 dash in great shape - its the blueish-grayish color
It does have the vent tubes and defrost vent but they are not on in the pictures.
I have the climate control bezel too for a extra $40.00 with dash - or alone $55.00 plus s/h
I dont have the radio bezel
Its in great shape - no rips, tears, cracks
I got it for my buddy but then we found a black one for his car
S14 KYB GR-2s with GoldLine Drop Springs - $200.00 OBO
1.75" drop - Great shape all mounted and ready to go.
240sx S14 Zenki 95-96 Front Lip
I have 2 of them
I will ship these for a extra $35.00 in the US
I have 1 set of OEM mounting hardware - $50.00 - $60.00 shipped in the US
Painted white - but paint is not sticking to well - normal scrapes on bottom - $100.00
Painted white - pretty beat up - 1 side got worn down - good to fix or make somthing with fiberglass - $40.00
JDS Performance is offline
Old 01-30-2010, 10:52 AM   #2
JDS Performance
Trader Rating: (53)
- I have 3 KA24DE motors torn down - let me know if you need anything off one I probably have it.
- S13 black valve cover - great for core @ poweder coater - $50.00
- S13 KA24DE Alternator - $45.00
- S14 KA24DE P/S Pump - painted silver - $45.00
- S14 A/C compressor and bracket - $60.00
- S13 stock Downpipe - $10.00
- 89' MT SOHC ECU - $50.00
- KA MT Flywheel - needs to be resurfaced - $45.00
- S13 & S14 KA starters - $50.00
- S14 valve cover gasket - used but in good shape - $8.00
- S13 Coil assembly - $30.00
- S13 headlight assembly w/ motor and new headlight - red - $40.00
- S14 IIAC and emissions stuff - $15.00
- S13 wiper motor - $10.00
- S13 MAFS - $25.00
- S13 Air box assembly - $20.00
- S14 Air box assembly - $20.00
- S13 stock ground wire - $5.00
- SR20DET tranny harness - $65.00
- S14 KA tranny harness - $65.00
- S13 manual door handles - $20.00
- S13 cruise control cable - $10.00
- S14 center bearing assembly - $35.00
- S14 auto shifter assembly - $20.00 - handle removed
- S13 A/C dryer w/ lines - $20.00
- S13 front bumper grill inserts - $15.00
- SR20DET "New" heat treated - pressure plate and flywheels bolt kits - $35.00
- (2) 2.5" coulpers - $10.00
- SR20DET Tranny Sensors - $35.00
- S14 grey center console - has a crack in the back - $30.00
- S13 SR20DET stock 02 sensor - $10.00
- Stock S13 SR20DET Pulley Kit (crank not shown) - $30.00 - ALt. sold
- Stock SR20DET FPR - $15.00
- Stock SR20DET oil pan - nice dent and a bung screwed in - needs a lil work - $20.00
- S13 polished intake pipe w/ black coiuplers - $45.00
- S13 rear knuckles and hubs - $50.00
- S14 auto drive shaft - $35.00
- S13 KA24DE TB w/ TPS - $45.00
Auto Meter Gauges;
- Pro-Comp Ultra Lite - Water Temp - short sweep - 2 5/8" - no sensor - $33.00 plus s/h
- Carbon Fiber - Ultra Lite - Air/Fuel Ratio - 2 1/16" - $25.00 plus s/h
- Sport-Comp - Boost/Vacuum - long sweep - 2 1/16" - $30.00 plus s/h
- Sport Comp - Oil Press. - Electric - short sweep - 2 1/16" - no sending unit - $25.00
- Fujita "New" Super Flow filter - $50.00
KA Rebuild Kits - Not syncros (those are seperate kits) - $99.00 - I have 2
S13-S14 KA24DE CRankshaft - I have 2 1 had a spun bearing (not bad) the other is in great shape.
S13-S14 240sx Cold Air Extension - should fit on both models and any intake - but I can not say for sure - $40.00
S14 ES Rear Cab set Bushing Kit - 7-3119G - $25.00 - Missing 1 bushing for the LCA
Old 01-30-2010, 10:53 AM   #3
JDS Performance
Trader Rating: (53)
S13 F&R Brake Calipers all hardware (except mounting bolts) - pads still have life left (1 front is missing a pad) - $40.00
S13 Front Brake Calipers all hardware "plus" mounting bolts - pads still have life left
S13 SR20DET Throttle Body with TPS - $25.00
S13 SR20DET Intake Maniold - $40.00
S13 KA Exhaust Cam - $30.00
S13 Passenger Side Door Bezel and Window Control - Missing cover but still work - $10.00
S13 Driverside Window/Door Controls - $10.00
S13 Mirror Controler - $5.00
Old 01-30-2010, 12:23 PM   #4
j20accord00
j20accord00's Avatar
j20accord00 is an unknown quantity at this point
Send a message via AIM to j20accord00
damn thats alot of parts..good prices too!
92 Coupe ka-t
j20accord00 is offline
Old 01-30-2010, 01:30 PM   #5
traxx07
Trader Rating: (63)
traxx07 is an unknown quantity at this point
Feedback Score: 63 reviews
how much for stock sr o2 shipped to 78221?
traxx07 is offline
Old 01-30-2010, 01:36 PM   #6
JDS Performance
Trader Rating: (53)
many years of 240s
Old 01-30-2010, 01:36 PM   #7
JDS Performance
Trader Rating: (53)
probably $3.00 s/h + part
Old 02-07-2010, 06:14 PM   #8
JDS Performance
Trader Rating: (53)
updated this thread
Old 02-11-2010, 06:31 PM   #9
JDS Performance
Trader Rating: (53)
list updated - send me some offers
Old 02-12-2010, 06:13 PM   #10
racerx2k1
460
racerx2k1's Avatar
Originally Posted by JDS Performance View Post
many years of 240s
updated this thread
racerx2k1 is offline
