Well for the coupe/roadster theory its simply because the coupe is a longet car, hence the longer exhaust. Now as for you wanting to make your exhaust zig zaged, BAD IDEA if you want power. All that will do is make excess backpressure inside your exhaust.
The race car thing with no exhaust, simple, highly built engines set up for no or little exhaust system. On your every day driver/weekend street racer you want a nice blend of free exhaust flow and backpressure. Flow of coarse higher. A nice strait exhaust with a good silencer/muffler at a reasonably sized pipeing will help you creat more HP than a windy, small, or over sized exhaust will.
To break it down really simple for our type of engine, no exhaust... Burned out exhaust valves/ o2 sensor. to restriced IE stock exhaust or clogged muffler.... clogged Cat converter and sluggish throttle response.
I hope some of my jibberish helps.
Later
Jim
'89 Fastback SR20det; Greddy Profec B II boost controller. HKS 262 CAMS. Greddy Radiator,pulleys,oilfilter relocation kit,boost gauge, rockerarm stoppers,intake manifold. Nismo Fuel Press Reg. Ferra duel Valvesprings, ti retainers. East Bear headlight conversion. Type X tail lights. Tien Suspension, Tanabe race exhaust. GT 16" rims, Walbro high Pressure fuel Pump, 7pt rollcage. HKS BOV. Mandril Exhaust Man. GTR FMIC. BeeR Valve cover. JE Pistons and Eagle Rods.
