Old 02-03-2010, 11:29 PM   #1
LJBS13
LJBS13's Avatar
Trader Rating: (22)
LJBS13 is an unknown quantity at this point
Feedback Score: 22 reviews
AIC Valve. removal?
92 ka24de. pretty much stock. idles at 1k but sounds like its misfiring. when i take off from a stop it bogs or misfires bad at low rpm. ive replaced spark plugs wires. cleaned the throttle body. i've been told it could be the IAC valve. can anyone help me out on how to remove and clean it? or if it could be something else. i've seached but havn't found anything on this topic. thanks
LJBS13 is offline   Reply With Quote
Old 02-05-2010, 11:44 PM   #2
rebornS14
rebornS14's Avatar
rebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of light
Send a message via AIM to rebornS14
do you mean the IACV? idle air control valve?
rebornS14 is offline   Reply With Quote
Old 02-06-2010, 12:07 PM   #3
LJBS13
LJBS13's Avatar
Trader Rating: (22)
yeah i messed up on the heading =/
Old 02-06-2010, 12:23 PM   #4
aznpoopy
aznpoopy's Avatar
http://zilvia.net/f/tech-talk/96967-...e-your-ka.html
Old 02-28-2010, 09:56 AM   #5
snappy
snappy's Avatar
snappy is an unknown quantity at this point
It's a great link, but some of the guys were inquiring about a high idle and whether or not the IACV/AAC is the cause. Their questions were never answered. My car idles perfectly but if I tap the accelerator it will stay at a constant 1500 or 2000 rpms for about 5 seconds and then drop back to down to a perfect idle.
I took it to a mechanic and he said it needed an new IACV/AAC but it was gonna cost too much to have him do it so I thought I'd check online first.
Also, my check engine light pops on and off every so often, it doesn't matter if the car is hot or cold it comes on at random. Is this also a cause of a dirty IACV/AAC?
Originally Posted by holemilk00 View Post
Its a 98 LE (leather edition)
snappy is offline   Reply With Quote
Old 02-28-2010, 06:01 PM   #6
steve shadows
steve shadows's Avatar
Dont do it, you'll regret it
Like Me on FaceBook !
Old 02-28-2010, 06:23 PM   #7
snappy
snappy's Avatar
Care to elaborate?
Old 02-28-2010, 06:44 PM   #8
steve shadows
Do you want to have solid idle control?
If you lighten your flywheel, go turbo and run open atmostphere etc etc, the IACV is going to be needed to smooth our your idle.
If you are planning on just having this car as a full blown race car and running the throttle screw over compensated with a 1500 RPMS base idle then be my guest
Old 02-28-2010, 09:15 PM   #9
snappy
snappy's Avatar
but what about if the idle is Ok but has has a higher rev for 5 seconds after you tap the accelerator?
... and would it cause the "check engine light" to come on?... Basically what I asked in my original question.
Old 03-01-2010, 12:01 PM   #10
jim1234664
jim1234664's Avatar
jim1234664 is an unknown quantity at this point
ive also had the same problem as you for years, in for the solution
jim1234664 is offline   Reply With Quote
Old 03-03-2010, 12:14 AM   #11
CrazyRob
CrazyRob's Avatar
CrazyRob is an unknown quantity at this point
Send a message via AIM to CrazyRob
by removal hes talking about taking it off the motor for disassembly and cleaning. not litterally removing the air idle control valve from the engine management. thats what i thought too at the title.
op:
download a factory service manual(fsm) and figure it out yourself.
CrazyRob is offline   Reply With Quote
