Old 02-02-2010, 07:48 PM   #1
isimon91
isimon91's Avatar
isimon91 is an unknown quantity at this point
Send a message via AIM to isimon91
S13 and SR20 parts..
Shipping: At buyer's expense
All prices are O.B.O., so shoot me an offer!
-Leather Solstice Driver's seat ($150)
got it from a certain shop. seat is mint, new leather.. SUPER comfy.. has decepticon logo, if that's what you're into..
-Full SR20 wiring harness ($300)
-Pulled from a S13 front clip, has EVERYTHING.
-T3/T4 .57trim 60comp Garrett Turbo ($300)
Minimal shaft play, ran fine and pulled strong. For $35 more buy it with the oil feed line.
-Peakboost Top Mount Manifold w/ 38mm Tial External Wastegate for SR20 ($550)
This is a top mount manifold, with the Tial wastegate welded onto the manifold.
-Peakboost 3" Stainless Downpipe ($200)
3" peakboost top mount downpipe for a top mount turbo (used in T3/T4 setup). Includes upper and lower downpipe.
-SR20DET 370cc Stock Injectors w/ fuel rail and FPR ($170)
Worked well before removed, low mileage. I upgraded to larger injectors.
-Greddy SR20DET Intake Manifold ($400)
-Great for high power applications, will include the cold pipe that fits.
-SR20 Mounting brackets (Make an offer!!)
Connects the block to the motor mounts
-FULL VMount Intercooler setup ($450)
Comes with C&R import racing radiator w/ single electric fans, custom radiator hoses (includes extra lower hose), modified greddy coolant surge/fill tank painted sparkly black w/ new rad cap, modified Greddy M spec intercooler core (painted black), steel hot pipe w/ nipple for wastegate hose, aluminum greddy flanged cold pipe
-OEM SR Shortblock ($400)
PERFECT SR bottom end, disassembled, come by and see the internals for yourself. Great if you want to put together a cheap swap, or if youre looking to build the motor.
-OEM SR20 Flywheel ($50)
Needs a light resurfacing, comes with all flywheel bolts.
-OEM S13 Suspension($125)
OEM Springs/Struts, no issues, drove fine.
-OEM S13 FLCAs ($30)
OEM S13 Front lower control arms, good condition, ball joints are slightly worn and should be replaced.
-OEM S13 RUCAs ($40)
No issues, selling b/c I needed adjustable rear camber.
-OEM SR20 O2 Sensor($50)
-OEM SR20 Transmission Gasket ($25)
-OEM SR20 Pulleys ($75)
Will include pulley belts for $20
-Greddy FMIC Kit for T3 Turbo ($200)
No issues, FMIC needs slight repair, bent mounting bracket. Easy fix with some JB weld.
-Aluminum racing radiator with 2inch core ($150)
No issues, fits S13 engine bay perfectly. Needs custom mounting brackets.
-OEM S13 Tie Rods
Never had a problem, came on a steering rack that I swapped onto my car.
OEM S13 Steering Rack
-OEM Spark Plug Cover ($30)
As it says, not much to it really.. No cracks, dents, etc etc.
If you have any questions, feel free to email me at [email protected] or just send me a PM.. Prices are negotiable.
Pictures:
Solstice seat
vmount intercooler
piping, etc
SR shortblock. perfect compression. come see the internals for yourself. just needs a little degreasing.
greddy fmic piping
upper peakboost downpipe
PM me if u need a pic of a specific part
1993 S14 SR Powered Hatch: Sold
1989 S13 SR Powered Coupe: Money pit
isimon91 is offline
Old 02-09-2010, 09:47 AM   #2
isimon91
isimon91's Avatar
Bump bump!!
All of these parts are in great condition.
.57 Trim T3/T4 should easily make up to around 300-400rwhp.
Nobody needs a full SR harness? Perfect SR shortblock?
Shoot some offers over!!
isimon91 is offline
Old 02-11-2010, 06:26 PM   #3
isimon91
isimon91's Avatar
bumpppppppppppppppppppppppp
isimon91 is offline
Old 02-11-2010, 07:29 PM   #4
Worfless
Banned from the Marketplace
Worfless is an unknown quantity at this point
id take the peak boost manifold if i didnt look retarded now..
Worfless is offline
Old 03-02-2010, 08:19 AM   #5
ichihachizero
ichihachizero is an unknown quantity at this point
I need the shortblock here do u live how
much to ship
to 78253
ichihachizero is offline
