![]() Join Date: Jul 2009
Greddy turbo timer s13
i got an s14 sr in my s13 and im trying to wire up my turbo timer..anyone know which wire on the harness by color is the speed sensor and parking e brake sensor wires?
tryin to install this and i dont have the 240sx harness for the tt so any help would be appreciated like maybe a complete step by step? |
![]() Join Date: Dec 2008
![]() Feedback Score: 7 reviews
your dash harness is still s13 correct?
Black - ground green - 12 v ignition blue - accessory red - 12 v constant search son...
"soft so you can't even enjoy it" |
completely my bad...first color is not a good way to solely tap into wiring... but
pin #52=Vehicle Speed Sensor(yellow/green) e brake is a ground just tap into brown wire off ebrake assembly. ![]()
![]() Join Date: May 2006
go buy this and be done with it simple plug and play.
ProjectSilvia Turbo Timer Harness 240SX '89-'94 - Turbo Timer Harness - ProjectNissan.com
#7 | |
53 Y/G Vehicle Speed Sensor edited other post
so hook up main harness and purple wire off of timer goes to vss yellow/green #52 wire brown goes to ebrake assembly... you dont need it though for operation.... esp. if you dont always pull up your ebrake.. btw greddy has all this info on their site...
i hate looking for stuff when i get a new part and all i wanna do is install and run with it already... haha so yea enjoy it. funny when old poeple flag you down..." sir your car is still on..."
And that seems to ne the pinout for a stock ka24de s13 ecu my car is an s13 but has a Silvia s14 sr20det ecu labeled "wc".. I need the wires for that
this one is off innovate motorsports...
1993 - 1996 Nissan Silvia S14 SR20DET (Non European) ECU Diagram ![]() Still #53 is VSS what year is your motor... Vss is prob the same.... if not go down by manifold close to firewall there should a be a two wire connector. one of those wires in that connector is the signal for the VSS. i have a toggle in my center console so if i ever so happen to go past 100 mph and still wanna go i just flip the switch and kill the signal.(thats a S13 w/ S13 blacktop) Thats a 1997-1998 S14 Sr20DET and vss is 101 my bad wrong diagram
"soft so you can't even enjoy it" Last edited by Prez; 03-15-2010 at 10:18 AM.. |
1997 - 1998 Nissan Silvia S14 SR20DET ECU Diagram
Printable (PDF) version Pin # Name Signal Type 2 Tachometer Signal RPM 16 Mass Air Flow Sensor Analog 17 Mass Air Flow Sensor Ground Ground 18 Engine Coolant Temperature Sensor Analog 19 O2 Sensor Signal Analog 20 Throttle Position Sensor Analog 21 Sensor Ground Ground 29 Sensor Ground Ground 32 Vehicle Speed Sensor Speed 101 Injector # 1 Speed 103 Injector # 3 Speed 110 Injector # 2 Speed 112 Injector # 4 Speed 116 Power Ground (Electronic Concentrated Control System) Ground 1993 - 1996 Nissan Silvia S14 SR20DET (Non European) ECU Diagram Printable (_PDF) version Pin # Name Signal Type 7 Tachometer Signal RPM 26 Mass Air Flow Sensor Ground Ground 27 Mass Air Flow Sensor Analog 28 Engine Coolant Temperature Sensor Analog 29 O2 Sensor Signal Analog 30 Sensor Ground Ground 38 Throttle Position Sensor Analog 50 Power Ground (Engine Control Module) Ground 53 Vehicle Speed Sensor Speed 101 Injector # 1 Speed 103 Injector # 3 Speed 110 Injector # 2 Speed 112 Injector # 4 Speed 116 Power Ground (Engine Control Module) Ground Source: http://www.innovatemotorsports.com/r...ecu_pinout.php
