Old 10-22-2003, 11:13 AM   #1
curbhuggerrps13
curbhuggerrps13's Avatar
curbhuggerrps13 is an unknown quantity at this point
Send a message via AIM to curbhuggerrps13
Question weird swooosh
my 93 fast back se makes a weird flyin saucer type noise whenever i drive everywhere..sounds like no other 240 out there. u think it is my lsd? cuz im shit out of knowin what it is. got my new tie rod!!!! and had a 3 inch magnaflow exhuast thrown on there =) what ia that damn noise? loud as my exhuast..lol and n e way to take away that truck soundin noise? like is it the tranny fan?
curbhuggerrps13 is offline   Reply With Quote
Old 10-23-2003, 11:49 AM   #2
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
Tranny fan?? As in someone who likes Rupaul??
It could be the mechanical clutch fan that cools the motor. It makes the 240sx sound like a damn Jeep Cherokee when it accelerates in low gear. You could always remove this and add dual electric fans....aftermarket...or...I hear certain Altima fans are upgrades for the 240sx.
-m
400x200
mbmbmb23 is offline   Reply With Quote
Old 10-25-2003, 02:51 PM   #3
datkwikracer
datkwikracer is an unknown quantity at this point
Send a message via AIM to datkwikracer Send a message via Yahoo to datkwikracer
pretty sure its your clutch fan, try this li'l test try to spin the fan with your finger if it moves a couple of inches then it's not the fan, if its hard to turn by hand then the fan is stuck and you should replace it because it can mess up your water pump since the fan is connected to it, i hear.
anyway its easy to replace and about $150 from courtesy nissan or some other online store, i replaced mine on my Z32 without disconnecting any hoses to the radiator i just removed the top fan shroud and removwed the 4 bolts then replaced it, i think u can get it fom the bottom fan shroud also. should take a half hour max.
datkwikracer is offline   Reply With Quote
Old 12-30-2003, 01:59 PM   #4
curbhuggerrps13
i know for sure it isnt the clutch fan cuz the noise is commin from the rear of the car..i just changed my vlsd fluid thinkin it was that but...it wasnt... bearing or somethin? cuz its alike really annoyin and makes me wanna rip my hair out..i just need somewhere to look? n e one have this prob?
Old 12-31-2003, 04:06 PM   #5
EchoOfSilence
EchoOfSilence's Avatar
EchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant future
Send a message via AIM to EchoOfSilence
last time i heard a swoosh from my car was when i had the spare emer. wheel on. dunno, jack her up and check
Petition Nissan to Make the IDx on http://IDxClub.co !
EchoOfSilence is offline   Reply With Quote
Old 12-31-2003, 07:04 PM   #6
phrozen
phrozen is on a distinguished road
Send a message via AIM to phrozen
BOV? haha maybe santa gave you a turbo for xmas:hammer:
phrozen is offline   Reply With Quote
Old 12-31-2003, 11:08 PM   #7
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
Could be a bad wheel bearing in the back. Try changing your LSD and transmission fluid and see if that helps.
-m
400x200
Old 01-02-2004, 07:33 PM   #8
curbhuggerrps13
thanks but i just changed my dif oil and yea,,still there i need to check the bearin...sounds good to me to inspect there...but its rainin...if the bearin isnt the prob..n e one wanna come down to my place and check it out?
