Old 03-16-2010, 09:49 PM   #1411
s142jzkillav10
s142jzkillav10's Avatar
s142jzkillav10 is an unknown quantity at this point
Send a message via MSN to s142jzkillav10
Question
Originally Posted by SuicidnS13 View Post
And also the car in primer with the fn's has 50mm widebody fenders molded on.
Ok but the Rear Quarter panels look like just a roll and Pull.
s142jzkillav10 is offline   Reply With Quote
Old 03-17-2010, 02:50 PM   #1412
1wheelwonder
1wheelwonder is an unknown quantity at this point
This is my favorite thread ever!
17x10 +35, 275/40/17 RT615s.
1wheelwonder is offline   Reply With Quote
Old 03-17-2010, 03:22 PM   #1413
GripTerror
GripTerror is an unknown quantity at this point
YAY! Awesome So sexy
GripTerror is offline   Reply With Quote
Old 03-17-2010, 03:26 PM   #1414
Z33dori
Z33dori's Avatar
that is pretty nice set up
Old 03-17-2010, 04:00 PM   #1415
1wheelwonder
Thanks guys, still need to pull a little toe out of the rear then I can move on to the front and make it worthy of this tread.
Old 03-19-2010, 08:14 PM   #1416
stockbee
stockbee's Avatar
stockbee is an unknown quantity at this point
Send a message via AIM to stockbee
I needed to see this picture. I was thinking about getting 285's instead of 275's here in the next month or so and that just made up my mind. lol, Thanks, and that looks sick.
stockbee is offline   Reply With Quote
Old 03-20-2010, 10:58 PM   #1417
240sxScores
240sxScores's Avatar
240sxScores is making a name for him/her self240sxScores is making a name for him/her self
Send a message via AIM to 240sxScores
Whats alignment settings? And how much clearance do you have inside.
240sxScores is offline   Reply With Quote
Old 03-21-2010, 03:56 AM   #1418
Xplat
Xplat is an unknown quantity at this point
Why must tires be so expensive?
I can spend about what my car is worth in tires alone -_-
Xplat is offline   Reply With Quote
Old 03-21-2010, 08:22 AM   #1419
1wheelwonder
Clearance is good on the inside as far as tire to inner well goes but the LCA is getting close to the wheel/tire ~1/2 of clearance id say. Id like to say a bigger tire would be a breeze to fit with some fine tuning.
Alignment specs are unknow at this point until I finish my frontend but ill be sure to edit my original post with the numbers.
Old 03-21-2010, 01:22 PM   #1420
chattslides14
chattslides14's Avatar
chattslides14 is on a distinguished road
Front 245/40/17 Falken ziex Work xd9 17x9.5 +17
Rear 275/35/18 Dunlop sport sp1 dsst Work xd9 18x10+18
chattslides14 is offline   Reply With Quote
Old 03-22-2010, 08:26 AM   #1421
s142jzkillav10
Ok I can see that the front fenders are aftermarket But the Rear Quarter panels do they have aftermarket oversized quarterpanels ???????????
http://i72.photobucket.com/albums/i1...x/100_2183.jpg
Old 03-22-2010, 09:09 AM   #1422
kingkilburn
Philosopher King
kingkilburn's Avatar
kingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfection
Is that a real question?
G O L D E N B E A R R E P U B L I C
kingkilburn is offline   Reply With Quote
Old 03-22-2010, 09:38 AM   #1423
bshotts
bshotts's Avatar
bshotts is making a name for him/her selfbshotts is making a name for him/her self
Send a message via AIM to bshotts
I think 275 is perfect on stock quarters with a roll and starts to look almost goofy with anything bigger without aero. I think you could go somewhat lower in front, but with your offset, 245 was a great choice. 255s are possible though!
Here's my 255/275 stagger, think I'm going to go a little lower in front and balance out rear side to side:
Quote of the year?
Originally Posted by projectRDM View Post
Zoom in a little more, it's not blurry enough.
bshotts is offline   Reply With Quote
Old 03-23-2010, 12:10 PM   #1424
luckyK
luckyK's Avatar
luckyK is an unknown quantity at this point
245/40/18s on all 4 corners with 7 or 8mm spacers, decent tire width for only an 8 inch wheel
Tires are Nitto Neogens, fenders are only rolled
how do most of you pull your rear fenders? I tried with a fender roller but I didn't want to break it because it's not mine..
but i kinda wana see how rear over fenders look with factory aero.. I'll be getting much more aggressive wheels of course to compensate.
luckyK is offline   Reply With Quote
Old 03-24-2010, 12:06 AM   #1425
s142jzkillav10
Offset is F18x9 +40 R18x10 +45
Tires are 255/35/r18 Rear's 295/35/r18
Work Meister S2's F18x9 +40 R18x10 +45 with Tires 114.3 5Lugpattern
Work Mister S2 18x9 18x10
WHEELS ARE!!! THANKS TO EVERYONE
Work Meister S2's I had them on the car for a week and have had them in the garauge for about 4months!!!!!
Tires are Front's 255/35/r18 Rear's 295/35/r18
Old 03-24-2010, 06:48 AM   #1426
SicBastard
SicBastard's Avatar
SicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the rough
Did you need a spacer in the rear with the 18x10 +45s? Are the control arms stock length?
BURN OUT IN YOUR FACE!
1998 S14 LS7/T56 swap in progress, build thread:
http://zilvia.net/f/tech-talk/147301...d-gto-pan.html
SicBastard is offline   Reply With Quote
Old 03-24-2010, 09:28 AM   #1427
bshotts
bshotts's Avatar
Impossible without using spacers as you would most def hit the rear lower control arm. I hit mine at exactly 188mm backspace....10 +45 is 193mm backspace. I'd guess he used a 10mm at least. As for the fronts...9 +40 is 168mm backspace which would also be impossible with coilovers which leads me to believe he's on lowering springs. Largest backspace I've seen with coilovers on S14 front is 158mm (Ray's 18x10 +18.)
Quote of the year?
Old 03-24-2010, 09:37 AM   #1428
s142jzkillav10
5mm Spacer needed for Stock struts but and so it wouldn't be so close to the lower control arm. due to the stocks being so wide it would rub when it squated or hit a big bump.
Old 03-25-2010, 11:26 AM   #1429
s142jzkillav10
The front did require about a 1" or 3/4 spacer due to the stock struts. But I never got a chance to try these with coilovers.
I had to make a desition power or looks and choose a gt4294 Jurbo.
Old 03-25-2010, 12:28 PM   #1430
NMs14.5kouki
NMs14.5kouki's Avatar
Trader Rating: (38)
NMs14.5kouki is an unknown quantity at this point
Feedback Score: 38 reviews
I have 30mm rear overs on stock jdm s14 aero, i think it looks really good, i will post some pics either later tonight or this weekend. its got tiny tires on it now tho, eventually will get a 255/275 tires.
NMs14.5kouki is offline   Reply With Quote
Old 03-28-2010, 05:49 PM   #1431
chattslides14
I still have front inner fenders The top of the tire is 1/2 inch from them. I won't take them out to go lower even though it would look better an inch or two lower in the front. My car gets around 100 miles put on it a day. It's just a nice daily driver. Your car looks mean though. Love the head lights
Old 03-29-2010, 07:24 PM   #1432
Drifting-pedobear
Drifting-pedobear's Avatar
Drifting-pedobear is an unknown quantity at this point
rear:
18x10.5 +15
265/40-18
100* of camber
roll, no pull
front:
17x10 +18
245/45-17
2.8* of camber
roll, no pull
Drifting-pedobear is offline   Reply With Quote
Old 03-29-2010, 07:37 PM   #1433
speedfiend
Trader Rating: (68)
speedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to allspeedfiend is a name known to all
Feedback Score: 68 reviews
Send a message via AIM to speedfiend
Yes that car has both front and rear widefenders. The rears are 50mm. That is a good buddy of mines car so I know this hahahha. And man it is looking good Mark.
Cameron
speedfiend is offline   Reply With Quote
Old 03-30-2010, 10:23 AM   #1434
JRas
JRas's Avatar
JRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfection
Send a message via AIM to JRas
Originally Posted by Drifting-pedobear View Post
rear:
18x10.5 +15
265/40-18
100* of camber
roll, no pull
pull those rears or get overs
JRas is offline   Reply With Quote
Old 03-30-2010, 10:08 PM   #1435
Drifting-pedobear
ive already got flares.
they are just not installed yet.
Old 03-30-2010, 10:16 PM   #1436
s142jzkillav10
Pic's aren't working
Old 03-31-2010, 11:17 AM   #1437
Drifting-pedobear
owl rly?!!!!
zg flares. boom.
Old 03-31-2010, 01:27 PM   #1438
ILoveMyRHS13
ILoveMyRHS13's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
Exceeded bandwidth, BRO. Try hosting them on Imageshack.us
Old 03-31-2010, 05:43 PM   #1439
GripTerror
lol fail .
Old 03-31-2010, 06:27 PM   #1440
DrtyRat
DrtyRat's Avatar
DrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfection
17x9+18 235/40-17
17x10+20 255/40-17
One of my all time favorite coupes (belonged to YucA http://zilvia.net/f/member.php?action=getinfo&u=27650 before it was stolen awhile back)
America... Too soft to place a killer in a well deserved tomb, But brave enough to kill a baby before he leaves the womb
DrtyRat is offline   Reply With Quote
