Old 04-06-2010, 05:07 PM   #1
element2301
element2301 is an unknown quantity at this point
I think i finally figured out what it does. I believe the wire is the SR a/c compressor wire and the other end runs to the iacv to kick up the idle when the a/c is switched on, so since im using codyace brackets and a KA a/c compressor i use the USDM a/c plug but will the iacv kick up wire still work on the dash harness if on the correct pin??? The way it seems is iff i just eliminate the wire going from the dash harness to the a/c compressor and just keep it going to the iacv it will still kick the idle up. Pleese correct me if i am wrong.
element2301 is offline   Reply With Quote
