![]() Join Date: Oct 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
Anyone know a source for a rebuilt A/C compressor? 98 240sx
None of the parts places locally are showing one in their catalog, neither is RockAuto.
Dealers want $500. I need to do some more diagnosis, but the low side is reading at 100psi AFAIK when the low side is high it's usually a compressor issue. I need to check the pressure switch and fuses first. However; it's hot here and I want to get the ball moving in case it's a compressor after all. Thanks Å
Now my Kensai, I curse you to be a Ronin and with the my remaining spirit I, beseech Chimata-No-Kami, to have you wander through time and distance lands, seeking a new master. |
Re: Anyone know a source for a rebuilt A/C compressor? 98 240sx
where are you located at? i work at a auto parts store here in socal. we can send your ac comp out for a rebuilt.
Sent from my T-Mobile myTouch 3G using Tapatalk |
I don't have a set of manifold gauges anymore. They were stolen when my workshop was broken into. I had a can of freon with a built in guage (low pressure fitting only). Fortunately my other A/C tools were left intact.
They had mentioned here they can send mine out for a rebuild. It's about 90 degrees though and it's my daily driver... This month has sucked. Needed a water heater, clutch/flywheel, 4 new tires, my dog got bit and needed stitches and I owed the IRS this year. I have a couple guys making phone calls around town looking for something. Anyone know how to bypass the pressure switch to see if I get good pressures once it's running? One my wife's saturn I had to do that to initially charge it. Maybe it's not the same on the 240sx (she only had two wires, mine has four).
Palm Beach County, about 7 hours south of you .
thanks...holding off on used at this time. Found a few online new/rebuilt for $190.
It kicked on for about 5 mins last night driving home. I am getting 12V (13.xx actually) at the clutch. I am going to check continuity this morning (too hot last night still in that area). I am suspecting it may be just a bad clutch....however may as well replace the compressor with 112,xxx on it and used probably all those miles here in S. Florida.
