Old 11-11-2003, 07:05 PM   #1
blu808
blu808's Avatar
blu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfection
Send a message via AIM to blu808
yea
You might want to keep your heater system since it is basically a second radiator. But you could allways eliminate the ac stuff. Also if you feel fine doing the wiring, then you should do it. Your car will look much cleaner. Also I will have my 240 finished with the weight reduction process next week and will get it weighed and post it up here. I believe the stock seats are around 25-30lbs with the rails. The stock seat belts in the s13s are also heavy.
Good luck. Luke
( Dons my nickname )
blu808 is offline   Reply With Quote
