Old 05-18-2010, 08:57 PM   #1
CinSun
CinSun's Avatar
CinSun is an unknown quantity at this point
Random SR20, S14 parts you need!!!
Please READ!!!
  • All parts are located in ONTARIO, CALIFORNIA 91761
  • Everything listed is used but in perfect working condition unless otherwise noted
  • All prices are OBO, but please don't waste my time with lowball offers
  • I will ship at BUYER'S expense, feel free to pm me for a quote and I'll get back to you ASAP
  • Local meetup/pickup is totally acceptable and preferred
  • Thanks for looking!!!
S13 SR20 Intake Manifold - $45
-the manifold will come with everything shown, EXCEPT the iacv. I'll also be throwing in brand new intake manifold gaskets.
S13 SR Flywheel - $40
S13 SR Exhaust Manifold - $50
-will come w/ 7-layer exhaust manifold gasket
S13 SR Throttle Body - $30
-comes with throttle position sensor as well. Will come with brand new OEM throttle body gasket.
S13 SR IACV x2 - $20 each
-I don't know if either of these work and I'm unable to test them, therefore I'm selling these AS IS.
S13 SR20 Oil Pump/Engine Front Cover - $150
-brand new, still wrapped in plastic
Adjustable FPR (fuel pressure regulator) - $70
-I'm not sure on the brand, but I was told this is either a Nismo or Tomei type-b universal FPR
S13 SR Ignitor Chip - $55
S13 SR20 Alternator w/ bracket and hardware - $90
S13 SR20 CAS (cam angle sensor) - $70
S13 SR20DET/KA24DE ECU Water Temp Sensor - $20
-brand new, never used
S14 KA/SR Dash Water Temp Sensor - $20
S13 SR20 PCV Valve - $10
S13 SR20 5 spd tranny - $225
-pulled from working setup. NO GEARS GRIND. Sensors, shifter, mounting brace, and clutch slave cylinder will be included. Tranny mount not included. There's a small leak in the rear where the driveshaft and tranny meet; the rubber seal/gasket needs to be replaced. This is a small fix. Local pickup/meetup only.
S14 Rear Seats - $75
-pickup/meetup only
S14 rear speaker deck cover/grilles - $30
-pickup/meetup only
CinSun is offline
240sx, ka24, s13, s14, sr20det
