Old 11-13-2003, 05:32 PM   #1
blu808
blu808's Avatar
blu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfection
Send a message via AIM to blu808
s13 Weighed My Car Today
Just weighed my 240 fast back. We have stripped it completely except for the dash and 2 stock seats. Removed all the rubber sound deadening, seam welded some parts of the car and cut out some of the sheet metal inside.
The total weight with the stock sr20 and a full tank of gas was
2440 LBS
Please post up if anyone else has weighed their cars I want to get an idea of what they weigh stock.
Thanks
Luke
blu808 is offline   Reply With Quote
Old 11-13-2003, 11:20 PM   #2
hondaguy
hondaguy is an unknown quantity at this point
Send a message via AIM to hondaguy
damn thats hella weight shaved off,but i bets its loud huh?well once u get used to it,it'll be alright,congrats on all dat weight.can u feel the difference?
if i had a dollar for every dollar i put in my car.........i would have all my money back
hondaguy is offline   Reply With Quote
Old 11-13-2003, 11:49 PM   #3
BeteNoir
BeteNoir's Avatar
BeteNoir is an unknown quantity at this point
You left the seats?!! You ain't hardcore man. I strip everything and sit on a bucket turned upside down
BeteNoir is offline   Reply With Quote
Old 11-13-2003, 11:49 PM   #4
holisticbeatz
holisticbeatz's Avatar
holisticbeatz is a well-known jackass
Re: Weighed My Car Today
I believe there's a factory sticker on the driver side door jamb that gives you that information. It should be there above the door latch holder.
Trust and I don't mean GReddy.
holisticbeatz is offline   Reply With Quote
Old 11-13-2003, 11:56 PM   #5
Maeda
Maeda's Avatar
Maeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura about
Where did you do this? I'm really interested in weighing and corner weighting my car.. ^_^
gutted everything except a stock passenger seat, with c/f hood, and light bucket for the driver. Next to go is the sun roof...
Maeda is offline   Reply With Quote
Old 11-14-2003, 12:20 AM   #6
JasonNagra
JasonNagra is an unknown quantity at this point
Send a message via AIM to JasonNagra
Maeda I'm doing the same thing. I just recently ditched my head liner, and have a few thoughts on losing the sunroof. How are you going to get rid of it?
http://www.imagestation.com/picture/...f/f9dc7664.jpg
Edit: check your link.
JasonNagra is offline   Reply With Quote
Old 11-14-2003, 09:38 AM   #7
blu808
blu808's Avatar
weight.
Yea I thought about doing a bucket turned over but it would make for interesting drifting.
I can feel a huge difference with the reduced weight.
My plans for this weeks weight reduction are to finish cutting out the unneeded sheet metal inside the car. Finish seam welding.
remove the rear bumper support, and put another coat of paint inside.
Future plans. and estimated weight
Plexiglass rear and side rear windows. (60-75lbs)
S15 front end.
1. CF hood 20 lighter
2. Fiberglass fenders 2-3 lbs lighter than the metal s13 fenders
3. fiber glass front bumper ( about the same weight as stock)
4. s15 headlights (20lb total weight saving from popups)
5. Sparco corsa carbon seats. 20 lbs lighter for both.
6. Fuel cell. 60lb weight saving.
7. Hollow out door shells. 25 lbs
Total. 147 lbs
Car estimated weight. 2093lbs
I should have the list complete within a month, except for the s15 which is backordered for a month or so.
We weigh our cars at a local truck weghing station. It is free and is open 24 hrs.
We found it to be accurate as well by weighing ourselves on it. I was 148lbs with out the car on the scale and with me and the car on the scale there was a 2240 lb difference, and when i stepped off of the scale it showed a reduction of 148lbs. (my weight)
Old 11-14-2003, 09:46 AM   #8
JasonNagra
What sheetmetal are you cutting away? I have a fastback as well. Also when you go to a fuel cell, do you lose fuel capacity and how does it work with the fuel pump? I'v always wondered about cells, just been too lazy to really look into it.
Old 11-14-2003, 10:13 AM   #9
blu808
blu808's Avatar
I am cutting out the metal inside the car. From the doors back to the taillights. Basically the inner part of the sheetmetal, I also remover the rear seat supports that are welded from the fender to the strut tower to the floor.
You can purchase just about any size fuel cell you want, so capacity is up to you. You cannot use your stock fuel pump. Fuel cells have built in sumps. You can only use a in line pump.
From the cell use stainless braided line to a in line fuel pump then to the motor. Then use a stainless braided line to the cell from the motor for the return.
Cells arnt really expensive but the lines and pumps make them expensive.
Luke
Old 11-14-2003, 01:32 PM   #10
Maeda
Maeda's Avatar
I'm going to make a carbon fiber or acrylic panel to cover it, and silicon it and use metal brackets to hold it on.
Then ditch all that heavy crap!
The c/f or arcylic panel will weigh like 2-3 pounds. =D
Oh and Blu if you can get this sucker down to 2000 pounds... YOUR ARE MY HERO!
Any thoughts on how I can lighten my S14 to that extent without losing much street drivability(daily driver)? o.O
Old 11-14-2003, 01:59 PM   #11
240Dave
240Dave's Avatar
240Dave is an unknown quantity at this point
None of that metal adds structure to the car does it?
You plan on running a cage or anything in there? What else is done to the car?
240Dave is offline   Reply With Quote
Old 11-14-2003, 02:02 PM   #12
JasonNagra
Thanks for the info guys!
Old 11-14-2003, 02:53 PM   #13
blu808
blu808's Avatar
LBS
Yes. Removing that sheetmetal will make the car flex more, but after the weight reduction is complete we are doing a 8 point cage, tied into the chassie, tower to tower (fr-rr).
I have only had the car about two weeks now so there is not much done to it yet. Heres the list.
1. 90 240sx fastback
2. SR20redtop
3. heat barrier coated intake manifold (had it laying around)
4. ACT 6 puck clutch
5. Aasco aluminum flywheel
6. Volk ce28n wheels 17
7. HKS super megaflow 5" filter (off of my z32s old setup)
8. KYB struts and tien springs (came with the car)
Here are the parts that are on order.
S15 front end conversion
Kaaz 2way diff
Tien HE drift spec coilovers
Cusco rear upper adj control arms
JIC hard tie rods
Suspension tech rear sway bar
Z32 brakes
Volk GTN wheels (track set)
Sparco Corsa carbon seats (black)
Sparco 3" camlock harnesses
Sparco fighter pedals
Halon 2 nozzle fire system
Greddy turbo extension
JIC turbo manifold
S15 turbo
HKS hi power exhaust
HKS down pipe
HKS SSQV bov
Border fuel rail
SARD 550cc injectors
Greddy VSPL intercooler
Greddy emanage with injector and ignition harnesses
Greddy EO-1 boost controller
255lph fuel pump
Apexi el series guages
and bla bla bla...
Anyways No its not my daily driver.
As for lightening your s14 I dont know much you could do without making it noisy inside.
Here are some.
remove ac. remove bumper reinforcments. Gutt the back half of the car.
Finish scraping the rest of the rubber crap off of the floor.
Luke
Old 11-14-2003, 04:08 PM   #14
RedlineRacer
RedlineRacer is an unknown quantity at this point
Send a message via ICQ to RedlineRacer Send a message via AIM to RedlineRacer
Re: LBS
That list is more than I have, and I have had my car for almost 6 months. Also, I am a struggling student.
RedlineRacer is offline   Reply With Quote
Old 11-14-2003, 04:16 PM   #15
adey
adey's Avatar
adey is an unknown quantity at this point
a note on your wheel choice:
CE28N are, afaik, Volk's lightest wheels.
GT-Ns, while looking better, are apparently significantly heavier, though. I'd consider using the CE28s on track and the GT-Ns for street.
Also, i hope you're an *extremely* safe and conservaiteve driver on public roads, because a car without bumper reinforcements is significantly more prone to serious damage than one with supports... unfortunately, I found this out first hand. Consider just cutting out some of the front support rather than losing it altogether; after all, you don't want that V-SPL to explode upon a 5mph front impact caused by some small patch of sand coming up to a traffic light!
BTW Good luck with the car -- I'd be very interested to see what it looks like both during your build-up process and when it's finished.
adey is offline   Reply With Quote
Old 11-14-2003, 04:42 PM   #16
Flybert
I would think since you're spending that much money, you wouldn't cheap out on coilovers. If I were you I would go for something with an inverted chock and aluminum shock body. It's not like it's going to make much of a dent in your pocket when you're buying all this stuff at the same damn time.
Old 11-14-2003, 05:44 PM   #17
adey
adey's Avatar
Re: LBS
Kaaz 2way diff
JIC hard tie rods
Z32 brakes
I don't think there's anything wrong with Tein HEs... they may not quite be Apex N1 Type Pros, but they're certainly going to provide better dampening than what he has right now.
What were you thinking along the lines of? Custom Bilstein double-dampening adjustable Dampers with custom H&R springs?
Old 11-14-2003, 06:37 PM   #18
blu808
blu808's Avatar
coils
I have used a few different setups in the past and have found the He's to suit my driving preferences best. You are right about the wheels but the GT-n\s are cheaper + I will prob use both at the track. Also I am a very safe driver on the street and only street drift on snow pass and hwy 9 late at night. Go slow on the straights and fast in the corners is what I like to do. Save it for the track as much as possible.
Anyways. I would like to post some pics asap. the only prob is I dont know how to post them.
If anyone knows how please let me know.
Thanks Luke.
Ohh yea. Does anyone want plexiglass parts. I get a big discount if i buy in bulk.
Same with carbon but the cat and resin is bank.
Old 01-23-2004, 12:37 PM   #19
hybrid_eg
hybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the rough
I will weigh mine pretty damn soon and revert back with the results. Mine is an 89 Coupe fully stripped, all sound deadening removed, along with all rear panels. I only have 2 door panels and shell of a dashboard, dashboard is stripped to the fullest, the only thing that remains is the cluster. If the car weighs in at 2500 it would be perfect.. we'll see..
hybrid_eg is offline   Reply With Quote
Old 01-23-2004, 12:41 PM   #20
Dousan_PG
Dousan_PG's Avatar
nothing wrong w/ HEs
lots of people use them
its not the coilovers that make the driver
i can put n1 pro on mine and still suck if i dont have skill
i know quite a fwe guys wh use them and would kick someones ass who has N1 pro
n1 pro is not the same style setup as HEs
different type of coilover for different applications
top of the line would be like advance design or ohlins compression and rebound adjust
Aaron
Pink GodziRa
Old 01-23-2004, 05:58 PM   #21
steve shadows
steve shadows's Avatar
my car wieghs in at 2500lbs even without driver and about 1/3 a tank of gas in it, its an sr powered hatch, mostly drag, some moutain runs, daily driver. I dont want to go any lighter thanks to both class wieght restrictions and i like doing top speed runs at least once in a great while....frisky haha.
Like Me on FaceBook !
Old 01-23-2004, 10:27 PM   #22
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
keep in mind gas is 8 or 9 pounds per gallon so dry your an extra 120 pounds less
wootwoot is offline   Reply With Quote
Old 01-24-2004, 11:16 PM   #23
blu808
blu808's Avatar
hum
Mine weighs 2440 with a full tank, and which racing class has a weight restriction?
Old 01-25-2004, 11:13 AM   #24
Mr. Foully
Mr. Foully is an unknown quantity at this point
Can you use stock bumpers without the heavy steel reinforcements? I was considering leaving them in but swiss-cheesing them. Weight removed that far from the car's Center of Mass helps twice.
As for stock, listed weight, don't believe it. Only trust a scale.
Clever, speed-related witicism ignoring the rules of fate, physics and common sense soon to be inserted here.
Mr. Foully is offline   Reply With Quote
Old 01-25-2004, 01:09 PM   #25
stillmatic
stillmatic's Avatar
stillmatic is on a distinguished road
Do you mind telling where this free truck weighing station in San Jose is...
stillmatic is offline   Reply With Quote
Old 01-25-2004, 01:48 PM   #26
blu808
blu808's Avatar
y
No prob. The weight station is over by san jose airport. Right off of de la cruz. If you come to the fat car meet we will be going to the same place.
Luke
Old 01-25-2004, 02:01 PM   #27
nightwalker
nightwalker's Avatar
nightwalker is an unknown quantity at this point
next step, do the little things... lighter lug nuts, titanium exhaust, changing bolts for zipties where possible, changing bolts for lighter bolts, JDM bumper support is also lighter, and shave all the hair on your body!
In life, we often cast the line of hope fishing for the best possible opportunity. Sometimes with enough effort, the things we catch are nothing short of amazing.
nightwalker is offline   Reply With Quote
Old 01-25-2004, 03:13 PM   #28
stillmatic
stillmatic's Avatar
Luke
Thanks. I'll definitely be going next month as long as my car is running.. Everytime there's a meet in the bay something bad happens to my car
Old 01-25-2004, 03:56 PM   #29
BurntRubber
BurntRubber is an unknown quantity at this point
my 1991 hatchback 5 speed weighs 2800 lbs. its bone stock with a spare.
BurntRubber is offline   Reply With Quote
Old 01-25-2004, 04:44 PM   #30
mixxamike
mixxamike's Avatar
mixxamike is an unknown quantity at this point
You guys ARE hardcore. I took my seat out two weeks ago to get it measured for my rollcage and the sound of the road in conjunction with my whining fuel pump is driving me insane. My goals are to make my s14 an extremely agressive racer while retaining all the luxuries of my fully loaded SE (and possibly some more sound deadening). I give you guys mad props for being able to put up without everything though
-Mike
mixxamike is offline   Reply With Quote
