Old 05-26-2010, 03:02 PM   #1
silviaguy240
silviaguy240's Avatar
Question 95 Sunroof Wiring issue
ok, let me preface this with the fact that i had an aftermarket security system in my car and accidentally cut the RED wire that goes to the sunroof.... now that the security system is out i have no idea where this red wire goes to.. i traced it all the way to the switch and read the fsm diagram but cannot make sense of where it is supposed to goto.... it runs down my A-pillar and then down to around where the cabin fuses are....after tha, i cannot figure it out...anyone know where this wire is supposed to go to?
Old 05-27-2010, 09:23 AM   #2
EDT007
EDT007's Avatar
EDT007 is an unknown quantity at this point
Is it similar to a 97'? Can you take a pic so I know which one exactly you're talking about? I have my car gutted and I can take some pics of the wiring for you.
EDT007 is offline   Reply With Quote
Old 05-27-2010, 05:37 PM   #3
silviaguy240
sunroof switch ^^
follows the A-pillar ^^
this one is kinda twisted but its where its coming down from the a pillar near the fuse box
and this is where im stuck, that is the power window relay is the blue box, but i cant figure out where that red wire goes to??
Old 05-30-2010, 02:14 PM   #4
idlafie
idlafie's Avatar
Is your sunroof a NISSAN OEM sunroof or an AFTERMARKET sunroof installed by the dealer when the car was sold. If it is an Aftermarket sunroof, then it's possible that red wire could just be the Power (+) wire that activates the motor. Nissan OEM sunroofs have the wiring harness in some sort of loom & never seperate like you have in the picture. If it is indeed an aftermarket sunroof, any FUSED dedicated 12 volt power line could power the sunroof...all you have to do is tap into a 12 volt line. Some people go direct to the battery, some the fuse block inside the engine compartment, while others take power off the driver side fuse block. Choice is up to you.
Anyhow, hope this helps....Good luck!!
ID
Old 06-01-2010, 08:20 AM   #5
projectRDM
projectRDM's Avatar
That is aftermarket. The OE sunroof power wire is white/black and runs down the passenger side Apillar. There is no wiring on the driverside Apillar besides the tweeter and the antenna cable.
FORMERLY R240NA
