Old 05-27-2010, 04:30 PM   #31
spools420a
spools420a's Avatar
spools420a is a well-known jackass
make sure you wear both your shoes not just one when you eye ball the timing,This could throw it off.
spools420a is offline   Reply With Quote
Old 05-27-2010, 09:17 PM   #32
Options13
Options13's Avatar
Trader Rating: (43)
Options13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the rough
Feedback Score: 43 reviews
ok so, once i adjust the cams, as long as there are 20 links between each mating mark, i should be golden right?
i just don't see how the 2 dark links on the timing chain will line up anymore after i adjust the cams, because they line up right now.
Options13 is offline   Reply With Quote
Old 05-27-2010, 11:59 PM   #33
slider2828
slider2828's Avatar
if that was true, then the bottom jumped.... an you are jacked... but try it anyways, if that is how your tdc looked like in the picture you posted, that is totally not right
Turn and Burn!
Old 05-28-2010, 07:07 AM   #34
jspaeth
jspaeth's Avatar
They will. You have to keep turning and turning, or the bottom end jumped, but it doesn't matter, you can keep rotating and rotating and eventually the links will be in the right places.
Be careful.....20 PINS BETWEEN the dots. By pin, I mean the rod that goes through 2 neighboring chain links and hold them together. 20 of THOSE between the mating marks.
Daily driven
Old 05-28-2010, 12:17 PM   #35
Options13
Options13's Avatar
Trader Rating: (43)
thanks for the help guys especially you jspaeth, i will have a video on Tuesday of the car RUNNING
gonna fix timing and put in a brand new wire harness, lets hope this is the end it all of problems..
Old 05-31-2010, 08:39 PM   #36
Options13
Options13's Avatar
Trader Rating: (43)
ok so i removed the chain tensioner, and the upper chain guide, i managed to get the exhaust side to where it needs to be, but holy shit the intake side would not BUDGE, there just isn't enough room/slack on the intake side, so i just put the exhaust side back to how it was and adjusted my cam gears... i took her for a drive and a HUGE difference, my exhaust sounds a lot better, and no more SURGING
but yeah look, no room
but heres how it sits right now
Old 06-01-2010, 12:16 AM   #37
slider2828
slider2828's Avatar
Well told you that was the problem, but that is just a band aid adjusting your gear like that.... I would really suggest doing it right.... Remove the cam and the caps and rest the timing.... I really doubt you can adjust it like that and be spot on... Put a timing light on it....
Turn and Burn!
Old 06-01-2010, 08:17 AM   #38
jspaeth
jspaeth's Avatar
Honestly, man, you didn't listen to us. We said to "zero" the adjustable cam sprockets, and do it the right way.....
I would need a picture from eye level with the top of the ehad to count the teeth.
Are you sure the first cylinder is at it's highest point (TDC). If so, it's porbably okay.
It would be good to keep cranking it by hand until the mating marks line up, just as a double check.
Timing light doesn't have anything to do with mechanical timing, only ignition timing and CAS-related stuff....
Daily driven
Old 06-01-2010, 12:29 PM   #39
slider2828
slider2828's Avatar
^^ Oh really? Thats interesting, but yeah, he should really do it the right way.....
Turn and Burn!
Old 06-01-2010, 12:41 PM   #40
Options13
Options13's Avatar
Trader Rating: (43)
well, this is just a quick fix, like i said, i tried to unloop the timing chain off, that shit would NOT come off, i was able to set the exhaust side to 12 o clock, but holy shit, the intake side would not budge at all, there is no room at all for the chain to come off... so i would have to completely remove the timing chain, so im either going to just order a new front cover, or a new timing chain, so i have motivation to do this whole operation.
Old 06-01-2010, 02:26 PM   #41
slider2828
slider2828's Avatar
Ghahaha Nice man! Yeah for there is 0 room for movement on the intake side.... You have to remove the caps for sure.... Its easiest if you have a buddy with you....
Turn and Burn!
