Old 06-18-2010, 10:17 AM   #1
Silvia_Drift
Silvia_Drift is an unknown quantity at this point
Originally Posted by bb4_96 View Post
what do you mean by falls off. be more specific.
The boost will hold steady at 19psi until I get to about 6600rpm. From then on all the way to the 8000rpm limiter, boost falls off to about 15psi before I hit the limiter.
Silvia_Drift is offline   Reply With Quote
Old 06-18-2010, 12:50 PM   #2
jspaeth
jspaeth's Avatar
There are a few things:
1) Boost leak (i had this and it only caused boost drop off at high RPM)
2) Wastegate flapper can't stay shut enough to hold boost
Daily driven
Old 06-20-2010, 09:45 PM   #3
Silvia_Drift
Checked for boost leaks. The whole system is mint with no leaks.
If the wastegate flapper can't stay shut, that would be a problem with the actuator correct? I don't think the actual flapper mechanism could be bad because it is a brand new GT2871R .64.
