Old 06-12-2010, 07:32 AM   #1
jdm_dean
jdm_dean is an unknown quantity at this point
Hard start when hot
Cold the car starts fine, just gotta rev it a little for it to stay running, after about a minute it stays running by itself.
After driving more than 20 minutes when i go to start it again, i have to start it and rev it fast or it will die and wont start for another 10 minutes.
It'll crank and try to start and you can hear an explosion like it starts then dies.
If I gas it while trying to start, it makes it start worse and it wont even have a full combustion cycle.
I'm stomped, tried cleaning the coolant temp sensor, same problem though..
jdm_dean is offline   Reply With Quote
Old 06-12-2010, 08:00 AM   #2
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
replace it dont just clean it and make sure u removed the right 1
Old 06-12-2010, 08:04 AM   #3
jdm_dean
i removed the one on the bottom radiator hose but realized thats just the switch for the fan. i removed the one ontop of the intake mani and cleaned it.
what exactly does a bad ct sensor cause the car to do..
Old 06-12-2010, 11:20 AM   #4
Duosx
Duosx has made poor choicesDuosx has made poor choicesDuosx has made poor choicesDuosx has made poor choicesDuosx has made poor choicesDuosx has made poor choices
whats your fuel setup?
Duosx is offline   Reply With Quote
Old 06-12-2010, 12:46 PM   #5
Neejay
Neejay's Avatar
Neejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfection
I'm having the EXACT same problem on my RB25. I even replaced the ECU coolant temp sensor. I think it's in the wiring somewhere, but I think the wire is shielded.
What motor do you have?
Neejay is offline   Reply With Quote
Old 06-12-2010, 01:18 PM   #6
jdm_dean
Stock fuel system...and stock ka24e
Old 06-13-2010, 05:44 PM   #7
Triperformance
Triperformance is an unknown quantity at this point
Sounds like a rich warm start senario, got any codes/ check engine light? Theres quite a few things that can do this as well.
Triperformance is offline   Reply With Quote
Old 06-14-2010, 07:38 AM   #8
jdm_dean
it is, if i pinch the fuel line the car runs better so its definately too much fuel. no codes though, thats the weird part :\
Old 06-14-2010, 11:23 AM   #9
Triperformance
Check your fuel pressure regulator and make sure it's functionng properly with and without vaccum. Do you have any codes/ check engine light on?
Old 06-15-2010, 09:30 AM   #10
jdm_dean
No check engine light. How would I check? Disconnect the vacuum line and see if the idle changes?
Old 06-16-2010, 11:38 AM   #11
Triperformance
Hmm, yes you can pull the vaccum line and see if idle changes. It could be possible you have a fuel injector issue (staying open). When was your fuel filter changed last as well?
Old 06-17-2010, 09:26 PM   #12
jdm_dean
It was changed about a month ago.
Only thing thats not leading me to believe its a fuel issue is that its just rich initially. Like once its running it runs fine other than a bog around 2500 rpm and when you floor it in a high gear, which i think is due to improperly gapped plugs, forgot to gap them once i put them in.
Its just once it first starts cold it wants to die unless you gas it and hot starts it wants to die unless you gas it but 2 mins later it will stay on by it self and drive fine.
Old 06-18-2010, 03:52 PM   #13
jdm_dean
Okay so I got it fixed. Checked my tps it was out of calibration, was at .39 and should of been between .45-.55. Got that set and got a new temp sensor from the junkyard, car cuts on every time now with no gas given.
Figured it out because when i disconnected the NEW ECT, it would idle lower and when revved it would backfire out the ass which is a sure sign of too much fuel. Reconnected it and idle raised, no backfire.
So if anybody has the same problem, definately check your tps and coolant temp sensor.
Old 06-18-2010, 04:10 PM   #14
Neejay
Neejay's Avatar
Thanks for the update. I'll check my TPS voltage...
