Old 06-18-2010, 12:13 AM   #1
gsracer
gsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond repute
How hard should i have to pull this damn handle ( hydro ebrake)
Man i installed a cnc brakes hydraulic ebrake in my car, plus new rear rotors and hawk pads.
I have bled each side 50 plus times, problem is that i have to pull it with pretty much both hands to get it to lock while going in a straight line.
Could it be the wheels? they are heavy work meisters 18 by 11 with bald 275s on the back?
This is driving me crazy!!!! Help!!!
ANTI-STRETCH NAZI
Vortech Supercharged Vh45de S14 V8nissans.com
gsracer is offline   Reply With Quote
Old 06-18-2010, 12:18 AM   #2
liv2drift045
liv2drift045's Avatar
liv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfection
Send a message via AIM to liv2drift045 Send a message via MSN to liv2drift045
ABS still hooked up by any chance? Buddy of mine installed PBM kit and brakes wouldnt look up, it wa because the ABS was engaging preventing lock. His handle wasn't as hard as your saying yours is though.
StreetSliders.Blogspot.com
liv2drift045 is offline   Reply With Quote
Old 06-18-2010, 12:24 AM   #3
gsracer
no abs is long gone, i mean if i get the car side ways mid drift it will lock like its supposed to but say i want to do an high speed initiation, all it does is slow the car unless i let go of the wheel and pull it with both hands.
I have noticed if i put my foot on the regular brakes a little bit the ebrake locks way harder.
ANTI-STRETCH NAZI
Old 06-18-2010, 12:27 AM   #4
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
DJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond repute
Feedback Score: 115 reviews
Send a message via AIM to DJPimpFlex Send a message via MSN to DJPimpFlex
I barely have to touch mine. I should take a video. In a straight line I have to pull it kinda hard, but as an initiation I only use 2 fingers. 17x10 with 235s
DJPimpFlex is offline   Reply With Quote
Old 06-18-2010, 12:29 AM   #5
BlueKpS13
BlueKpS13's Avatar
BlueKpS13 is a name known to allBlueKpS13 is a name known to allBlueKpS13 is a name known to allBlueKpS13 is a name known to allBlueKpS13 is a name known to allBlueKpS13 is a name known to allBlueKpS13 is a name known to allBlueKpS13 is a name known to allBlueKpS13 is a name known to allBlueKpS13 is a name known to allBlueKpS13 is a name known to all
Try running smaller width tires, and a high PSI. Or just tap the brake when you pull the ebrake handle, if its working, why change it
BlueKpS13 is offline   Reply With Quote
Old 06-18-2010, 12:34 AM   #6
gsracer
well i just installed it, the way i see it this is not workinng properly, being that a stock cable ebrake will lock the tires at 80mph, i dont understand what the hell is wrong with this thing.
ANTI-STRETCH NAZI
Old 06-18-2010, 01:26 AM   #7
NMs14.5kouki
NMs14.5kouki's Avatar
Trader Rating: (38)
NMs14.5kouki is an unknown quantity at this point
Feedback Score: 38 reviews
what rear brakes are you using?
NMs14.5kouki is offline   Reply With Quote
Old 06-18-2010, 01:30 AM   #8
gsracer
sorry z32 rear brakes
hawk pads
new rotors
stainless steel lines
etc
ANTI-STRETCH NAZI
Old 06-18-2010, 01:44 AM   #9
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
godrifttoday is an unknown quantity at this point
Feedback Score: 82 reviews
it does work how I made this... It was that my line was kinked causing no fluid... But anyhow is this how it ebrake set up is? Mine works! Follow the diagram
godrifttoday is offline   Reply With Quote
Old 06-18-2010, 01:48 AM   #10
gsracer
thats exactly how mine is setup.
How much free play is in yours ?
ANTI-STRETCH NAZI
Old 06-18-2010, 01:49 AM   #11
godrifttoday
Trader Rating: (82)
I would say almost none... Before I bleed it it has plenty of play is ur lever going down? Does it stay up by itself?
Old 06-18-2010, 08:58 AM   #12
gsracer
it stays up by itself, like i posted above if you give the footbrake a bit of pressure at the same time as pulling the ebrake, the handle gets hard and then locks fairly easyily.
ANTI-STRETCH NAZI
Old 06-18-2010, 03:11 PM   #13
bb4_96
bb4_96 is an unknown quantity at this point
if you had an ls you wouldn't even need the stupid thing
bb4_96 is offline   Reply With Quote
Old 06-18-2010, 04:58 PM   #14
gsracer
what, an ls what ls1, lol? what i have is better haha
ANTI-STRETCH NAZI
Old 06-18-2010, 08:41 PM   #15
cheap_sticker05
cheap_sticker05 will become famous soon enoughcheap_sticker05 will become famous soon enoughcheap_sticker05 will become famous soon enough
My corolla was like this too. A friend suggested I install a proportioning valve. That was it, after that it worked fine. Haven't had one on a 240 though so I can't say for sure. The added capacity to the brake fluid is what messed mine up. Even my brakes were softer before I installed the valve.
cheap_sticker05 is offline   Reply With Quote
Old 06-18-2010, 09:00 PM   #16
gsracer
well i figured a few things out and will be doing a custom wilwood setup, the cnc doesnt have the balls to lock up the rears with big tires at high speeds without working the front brake at low speeds <50mph it works great, but i want it for the high speed stuff.
ANTI-STRETCH NAZI
Old 06-19-2010, 12:25 AM   #17
ak_slick
ak_slick will become famous soon enoughak_slick will become famous soon enoughak_slick will become famous soon enoughak_slick will become famous soon enoughak_slick will become famous soon enough
Did you try to switch the lines on the brake itself (from bmc and to rear) They are probably backwards... There are two styles of cnc hydro brakes I have seen and they hook up backwards from each other.
Chances are they are backwards if you haven't tried swapping them it is worth a shot. Mine locks up my Nitto555 275 with my pinky finger at 60mph with ease.
ak_slick is offline   Reply With Quote
Old 06-19-2010, 12:36 AM   #18
gsracer
yep i switched the lines way in the beginning just to be sure.
ANTI-STRETCH NAZI
Old 07-04-2010, 10:10 PM   #19
NickyD0403
NickyD0403's Avatar
NickyD0403 is a jewel in the roughNickyD0403 is a jewel in the roughNickyD0403 is a jewel in the roughNickyD0403 is a jewel in the roughNickyD0403 is a jewel in the roughNickyD0403 is a jewel in the roughNickyD0403 is a jewel in the roughNickyD0403 is a jewel in the rough
I'm having the same problem! I'm running a CNC E Brake with Brembo rear brakes. It shouldn't have any problem locking. I just bled my system, AGAIN.
Would playing with the adjust lock nut on the cylinder help possibly? I'm running 18x10.5 with a 255, straight line is damn near impossible to lock up, turning it'll chirp the tires but no serious lock. In order to get that chirp I had to push the lever HARD. I have an event Saturday I'd like to get this thing working...
NickyD0403 is offline   Reply With Quote
Old 07-04-2010, 10:26 PM   #20
alesserfate
alesserfate is an unknown quantity at this point
hmmm...
you shouldn't have to pull it very hard, i ran 18x11 weds kranzes with 275/35 toyo t1r's on them and entering a large turn in 4th maybe 160-170 and i would clutch in and yank it not very hard, no muscle effort at all really and im pretty skinny
alesserfate is offline   Reply With Quote
Old 07-04-2010, 10:29 PM   #21
NickyD0403
NickyD0403's Avatar
I didn't try locking it up with added pressure from the footbrake, though. I just came home from driving it and looked this up. I'll try that tommorow. Maybe it'll lock better on the 235's at the event
Old 07-04-2010, 10:39 PM   #22
Def
It's probably too large of a MC or too low of a lever ratio so you can't generate enough force with your hand to lock up the rear wheels. A smaller MC or a higher lever ratio will trade more travel on the lever for more brake line pressure.
DEFSPORT
Old 02-22-2011, 09:51 PM   #23
KansaiDrifter
KansaiDrifter's Avatar
KansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud of
kinda bump from the dead but i've just installed a cnc and a pbm hydro setup (on different cars) both of these have the same problems like listed, hey both dont seem to help any, infact they take more effort then the factory handle. Did anyone resolve this issue? I'm planning to call pbm tomorrow and ask, so far it's a waste of time
KansaiDrifter is offline   Reply With Quote
Old 02-22-2011, 10:58 PM   #24
uperformance
uperformance is an unknown quantity at this point
uhhh oh. i just finished doing cnc hydro in my track car for this season, completely removed the oem z32 ebrake tho, i hope im not regretting this.
uperformance is offline   Reply With Quote
Old 02-23-2011, 01:16 AM   #25
hessianben
hessianben is an unknown quantity at this point
I found same thing- hard to lock rear in a straight line.
however, with just a slight weight transfer to the front, it locks super easy.
i have to give it a quick stab of foot brake before i pull the hand brake, but with that done, it locks just fine.
hessianben is offline   Reply With Quote
Old 02-23-2011, 07:37 AM   #26
o0o
o0o's Avatar
o0o is an unknown quantity at this point
lol maybe got some air in the brakelines?
o0o is offline   Reply With Quote
Old 03-16-2011, 10:35 PM   #27
maxtrbo93
maxtrbo93's Avatar
maxtrbo93 is an unknown quantity at this point
How many of you are running ABS with your hydro setups?
I have a RPS13 with ABS and want to run a hyrdro ebrake kit.
Will this still work?
2002 IS300 - www.poorform.ca
1991 Nissan Silvia S13 (Two Tone)
maxtrbo93 is offline   Reply With Quote
Old 03-16-2011, 10:49 PM   #28
o0o
o0o's Avatar
i think it should work and you can get used to it after a time...but if you're putting a hydro ebrake in your car you're not going to drive like a daily mommy or? so get the abs out to have real fun
Old 03-16-2011, 10:52 PM   #29
maxtrbo93
maxtrbo93's Avatar
I'd really like to get the ABS out but i hear its quite the job to do, dont suppose there are any kits out there to buy to delete it?
Old 03-16-2011, 11:52 PM   #30
o0o
o0o's Avatar
whats so difficult? get a non abs master in there and customize you pipes a bit, finish.
maybe won't look too nice if u do pipes first time but that should be all...
google there're alot of diy's around how to remove abs
