Old 07-26-2010, 11:05 PM   #1
Jonnyblaze
Jonnyblaze's Avatar
Jonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymore
Really weird transmission problem.
Hey guys I did a 5 speed swap on my s13 about 1,000 miles ago and it was just perfect for the first 500 miles. After that it would start to grind when shifting 1-2 at high rpm. It got progressively worse and began to happen in other gears as well. Now it will grind every other time I shift in almost every gear. The weirdest thing is today i revved the car with the clutch down and the shifter in neutral and it was grinding until I released the clutch. When I'm reversing or moving slowly in first and then press the clutch down and leave it in gear it will grind. Any ideas on what the problem is? Input shaft bearing? Throw out bearing? Thanks for the help.
'91 Hatch - Work in Progress
Jonnyblaze is offline   Reply With Quote
Old 07-27-2010, 12:08 AM   #2
Jonnyblaze
Jonnyblaze's Avatar
Could the input shaft be toast from all the grinding?
Old 07-27-2010, 12:20 AM   #3
davirene
davirene's Avatar
davirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nice
Throw out bearing....
davirene is offline   Reply With Quote
Old 07-27-2010, 12:30 AM   #4
Slidin' Sam
Slidin' Sam's Avatar
Slidin' Sam is an unknown quantity at this point
pull the mission, change release bearing, check the spring for the clutch fork (I had one snap on me before) and inspect your clutch/flywheel assembly and make sure everything is properly torqued and in good condition. Also, check your gear oil level.
Slidin' Sam is offline   Reply With Quote
Old 07-28-2010, 02:34 PM   #5
volkrps13
volkrps13 is an unknown quantity at this point
sounds like you need a new release bearing
volkrps13 is offline   Reply With Quote
