Old 07-30-2010, 12:50 PM   #13
dr.klawn
dr.klawn's Avatar
dr.klawn is an unknown quantity at this point
Originally Posted by NiSilS14 View Post
Assuming the system is bled and everything is in working order. It sounds like to me you have a airflow problem. At highway speeds the air is simply not going through the radiator, it's just going around it. Create some ducting so that air will be forced to go through the radiator. Same thing was happening with my friend's S2000, made some ducting from the intercooler to the radiator, problem went away.
so u put a shroud around the i/c going to the rad... i'm close 2 puting a small puller fan on the back of my i/c so it blows air right @ mine but the shroud/ducting sounds better
dr.klawn is offline   Reply With Quote
