![]() Join Date: Jun 2006
![]() Feedback Score: 20 reviews
Tapping for multiple RPM signals........
I have a number items to install which require an RPM signal. Where can I retrieve this signal and what is the best method of branching it to multiple units?
Will branching the signal to multiple units weaken the signal to each unit? Will tapping into the wire interfere with the ECU? The car is an S14 and the engine is an RB25DET......... |
#2 | |
Well, my Eboos2 needs an RPM signal, two step rev limiter, turbo timer, and anything that may be used in the future. I am worried that if I simply just tap the wire from the ECU, and branch out to all these units, it will cause weak signals and harm to the ECU. I am wondering if there is a way to amplify the signal and use a junction area to branch to each unit. |
signal
I pretty much know where I can get the signal from, however I don't know how branching it off into multiple units is going to react. By adding much more wiring to that circuit, I would changing the resistance of that circuit.
on a rb you must tap of the tach signal wire with a gold solder and a pretty decent wire, then tap as many things as you want.
and make sure you use a signal ground from your ecu or somewere. |
what he meant is make sure you use gold connectors, gold material is best for electric transfer.
Originally Posted by EDaciouSX You should fix your opor grammar. |
![]() Join Date: Jan 2008
as long as you dont have miles of wire for the signal to travel through, you should be fine. Branching a signal means dividing the circuit into parallel connections, therefor voltage stays the same which ultimately means in theory that the signal should be the same at each unit you are trying to connect. It will be the current that is weaker, but that is not how the electronics interpret an RPM signal.
#11 | |
straight from my electrical book. Conductor Rating (starting with the best) 1. silver 2. copper 3. gold 4. aluminum 5. tungsten 6. zinc 7. brass (copper & zinc) 8. platinum 9. iron 10. nickel 11. tin 12. steel 13. lead |
#12 | |
#13 | |
